Amplifier Install HELP
Old May 12, 2018 | 11:52 PM
  #41
Bchester6's Avatar
Originally Posted by Marcos Gonzalez
hey i was wondering if you have a pik of the groumet you pass you power cable thru and the location exactly. I have a 2011 acura tsx wit non navigation
Directly behind the accelerator pedal if I remember correctly... A perfectly designed little entry point for power wire.
Old May 24, 2018 | 11:34 AM
  #42
TSX1012m6's Avatar
That gromet is on the left side of the brake pedal. It is actually the stopper for the clutch pedal, if the car is manual you cannot use that grommet.
There is a large grommet in the engine bay that has a lot of wires running through it. Circled in the photo below. You can add a small slit in the grommet using a knife (very small) and run the power wire through there. It will show up behind the dash on the passenger side. If you run it far enough through it will appear cleanly on the passenger floorboard. Thats the way I ran mine.
Feb 25, 2020 09:57 AM
tpraka300
3G MDX (2014-2020)
57
Dec 10, 2018 02:17 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
