2nd gen TSX door speaker removal/install instructions
Old Apr 15, 2010 | 05:42 PM
mercman's Avatar
Here are some instructions for removing the door panels and installing aftermarket speakers in the 2nd Gen TSX.
Note: the Base package or premium system TSX does not use rear door speakers. Only the “tech” ELS system uses the rear door locations.
My goal was to avoid drilling and cutting so I can put it back to factory when I turn it in at lease end. You are free to drill and cut anything you want but I’m not telling you to do that. Also, if you break something I didn’t tell you that either, you work at your own risk.
The ELS system can handle a two ohm speaker but I recommend going with a four ohm. The technical reasons are a subject for another post, let’s keep this to the door and rear deck 6.5s and save the subs and amp questions for other posts. I haven’t had a chance to look at the base amp so I don’t know what your speakers are, you are always safe with 4 ohm and you’re not giving anything up if the factory speakers are 2 ohm. Again trust me on this.
I installed components up front and ordered a set of tweeter covers form the dealer (9 bucks each) so that I could mod them to fit my tweeters. I will show how I did this as soon as I have more time.
Just about any 6.5 inch speaker will fit but all will need a spacer, typically ¾ inch. The aftermarket does not have a direct fit spacer like the 1st gen has so you will have to use universal ones or make your own. The important think is not to let the speakers hit the door glass.
For the adapter (speaker wiring) it is the 1990 and up Honda.
Tools, basic hand tools,
A small flat blade or “pick”
Rubber mallet
Trim removal tool(s)
Plumbers Putty
Roll down the windows
You will have to disconnect some wiring harnesses so I recommend disconnecting the battery
Keep track of the screws, some have shoulder and some don’t remember where they go.
When you get all the screws out and clips release lift the door panel up slightly to release it from the top of the door. Be very careful not too pull it away too far from the door; you have lots of stuff to disco like the door latch assembly and electrical connectors.
The connectors all have some kind of “catch” or locking tab, be sure to use it before pulling.
This is mostly a photo step by step.
Some tools
Roll down the window and remove the tweeter cover, unclip the connector.
I’ll add the info on the tweeters when I get a chance. I have to get busy on the amp bypass projects.
Jeff
Old Apr 15, 2010 | 05:59 PM
09TSXTech's Avatar
Mercman, excellent step by step writeup.
Old Apr 15, 2010 | 08:10 PM
patcracks's Avatar
yea man thats alot of work nice job
Old Apr 15, 2010 | 09:41 PM
civichbdx's Avatar
Sweet job man
Old Apr 15, 2010 | 09:58 PM
win2k8's Avatar
what kind of aftermarket speakers are those? And after replacing the door speakers does the distortion go away or is barely noticeable?
Old Apr 16, 2010 | 12:16 AM
cb1021's Avatar
I remember there was a link posted some time ago with the speaker bracket from crutchfield for those of us who can't make a wooden one like ours.
Does anybody have a link?
Old Apr 16, 2010 | 10:02 AM
bjohnston115's Avatar
well done, very professional looking... If my speakers blow agian (3rd time) i will be doing this.
Old Jun 1, 2010 | 04:44 PM
lightjak_tsx's Avatar
very nice... thanks for all the info and pics.
Old Jun 14, 2010 | 04:43 PM
juy_socal's Avatar
Thanks for posting. This is very helpful. Can you tell me what is the depth limit on the front doors? I am thinking of installing HAT Clarus components in the front doors, Do you think 1/2 inch spacer is enough?
Old Jul 9, 2010 | 08:05 PM
TSX_BlackPearl's Avatar
hello mercman where is the amp located on the tsx 09 nav!!! i want to put some amps in my car can you please let me know...
Old Jul 13, 2010 | 07:35 PM
HEY mercman do you have the tsx 09 amp pin diagram i wan to instal 2 JL amp in my car
Old Jul 26, 2010 | 11:50 AM
mercman's Avatar
The amp on the 2G TSX is located behind the passenger side trunk side panel.
You can’t connect the amp directly to the HU, you have to be on the speaker side of the factory amp.
I have been away feverishly working on an ELS solution. I have successfully tested the proof of concept preamp this weekend (using the ELS HU to control my preamp). I am working on the prototype and do not anticipate any problems with the design.
I pointed out in another post that the ELS amp has a very heavy handed EQ specifically for the factory speakers. It does not sound so good when you install aftermarket speakers. My preamp will eliminate the factory amp and the ELS EQ.
Jeff
Old Jul 30, 2013 | 08:17 AM
D4nnyD's Avatar
Anyone know the diameter of the mounting hole? i have some eminence Alpha 6 speakers which have quite large magnets. I was wondering if these would fit.
Any help is appreciated. Thanks
Old Jul 30, 2013 | 10:32 AM
skathe's Avatar
Danny get a spacer, i had to get a 1 inch spacer for my jl c3-650s
Old Jul 30, 2013 | 12:10 PM
iSeeYouTwo's Avatar
This step by step would be cool if the pictures weren't so tiny... can't read anything, lol. And I need to remove my panel soon! Any other DIY's around?
Old Jul 31, 2013 | 03:49 PM
D4nnyD's Avatar
thanks Ill try and see if that will work. With that 1 inch spacer in, does the speaker not press up against the door panel though? Or is there some room in between there?
Feb 25, 2020 09:57 AM
obert
Oct 29, 2015 10:37 PM
EE4Life
Sep 11, 2015 10:13 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
obert
Sep 3, 2015 08:40 PM
