Wiring diagram for 2nd gen TSX?
Gets bored easily
Does anyone have a wiring diagram for a second gen? Yes, I know I can purchase one off eBay, etc, as part of a whole lot of information... I'm looking for something already available online. I don't feel like paying $50 for something I have only one use for, for two days (indep foglight mod).
Thanks!
Thanks!
TSX 2009 -2010
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) 50 AMP @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 2
STARTER YELLOW (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 1
STARTER 2 N/A
IGNITION 1 BLUE (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 5
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 3
ACCESSORY/HEATER BLOWER 2 RED (+) @ IGNITION SWITCH, (WHITE, 5-Pin Plug) Pin 4
KEYSENSE N/A
PARKING LIGHTS ( - ) GRAY (-) @ HEADLIGHT SWITCH, (BLACK/WHITE, 12-Pin Plug) Pin 11
PARKING LIGHTS ( + ) RED (+) Left Front and Rear) @ DRIVERS FUSE BOX, (LT. GREEN, 16-Pin Plug) Pin 11
POWER LOCK ORANGE (-) TYPE B, @ POWER WINDOW MASTER SWITCH, ( GRAY, 37-Pin Plug) Pin 28
POWER UNLOCK BROWN (-) & WHITE (-) TYPE B, Requires Double Pulse @ POWER WINDOW MASTER SWITCH, ( GRAY, 37-Pin Plug) Pins 29 and 31
DOOR TRIGGER BROWN (-) @ DRIVERS FUSE BOX, (LT. GREEN, 16-Pin Plug) Pin 12
DOMELIGHT SUPERVISION PINK (-) below DRIVERS FUSE BOX, (WHITE, 20-Pin Plug) Pin 1
TRUNK RELEASE PINK (-) @ DRIVERS FUSE BOX, (LT. GREEN, 20-Pin Plug) Pin 3
SLIDING POWER DOOR N/A
HORN ORANGE or GRAY (-) @ HORN SWITCH or DRIVERS DASH FUSE BOX, (LT. GREEN, 33-Pin Plug) Pin 23
TACH Any wire NOT YELLOW/BLACK @ Any FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE LT.GREEN (+) @ BRAKE SWITCH or DRIVERS FUSE BOX (LT. GREEN, 33-Pin Plug) Pin 20
FACTORY ALARM DISARM See UNLOCK
ANTI-THEFT HONDA'S TRANSPONDER SYSTEM, Requires Bypass Module,
PART COLOR LOCATION
STARTER 2 N/A
IGNITION 2 N/A
IGNITION 3 N/A
KEYSENSE N/A
Katamatik (10-14-2022)
Gets bored easily
Thanks Lopez...do you have anything that speaks to the wiring colors of the fog lights though? I'm looking for basically all the colors of the wiring coming off the headlight stalk, by harness if possible...
same here
i have been looking to do this since the day i bought my car.
i want my fogs to be linked to the parking lights so they come on with the parking lights and stay on with the headlights. they will work with auto, and wont stay on when the car is off. and i dont need a new separate switch either.
i do know that you can order the entire car's electrical manual online, its close to a $150 i think.
i asked the dealer if they could do it for me, but they would, and said id have to go to an audio shop. just havent found the time yet.
good luck
good luck
Gets bored easily
There are many wires on each harness (I can remember at least 6 offhand) in the steering column alone - at least 4 or more on each. Hence the need for a diagram explaining what colors do what
Sorry to resurrect this thread. But in the list provided in post #2, I did not see the wiring info for the power dimming rear view mirror. I would like to know where to hookup my invisicord for my Escort radar detector. Could someone please provide the info for 12V and ground wires/pins?
In addition, I too am interested in the independent (or on with parking lights) fog light mod. Can someone please elaborate on this? I'm not electrically inclined, so this will be intricate for me
thank you in advance.
there is a DIY for the indep foglights, seems like fun times, do a search for it, im too lazy to find you the thread. i believe there may be details on the invisicord install too
pyro, thanks, but I checked the searches already, and all that's there for DIY fogs is one for a 2008 TL, and a 1st Gen TSX. I would think that the harnesses don't apply to our current gen/model.
Does anyone out there have the wiring diagram for the power mirror and a DIY for independent fog light control? thanks.
here ya go
https://acurazine.com/forums/showthr...dependent+fogs
also
https://acurazine.com/forums/2g-tsx-audio-bluetooth-electronics-navigation-304/passport-8500-hardwire-install-847570/
and
https://acurazine.com/forums/showthr...ght=invisicord
2003 Tl type S
Hey you guys, I'm new here so bare with me. I bought a power window universal remote for my 03 TL. I had an issue with the control unit in the driver side door and didn't want to spend 200 plus it seems this remote does a little more that the original. I have looked up and even bought the diagrams for the entire car and it's a little tricky for me. I've gotten to a point where I'm gonna have to buy the new one which is cool, however if anyone can give me a color code or diagram to hook this remote up to this car I'd really appreciate it. I've flipped from diagram to diagram tracing these wires and I'm just not figuring out where all the wires go.
Thank You,
Jeremy.
Thank You,
Jeremy.
SidhuSaaB
05-30-2020 12:40 AM
SUPRMN84
10-07-2015 09:46 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
