Tsx low washer message
Old Aug 20, 2012 | 10:28 AM
JTRADAR61's Avatar
Has anyone added Canada washer tank to their us spec Tsx? The Canadian spec has 2.2 more liters of capacity than us spec and low fluid level. Does anyone know if wiring harness in us models has the plug for low washer level ? If anyone has any suggestions or ideas responces will be appreciated .
Old Aug 20, 2012 | 01:30 PM
Domm's Avatar
What you're trying to do is more trouble than it's worth. Just refill the fluid more frequently if you use the windshield washer often. If you use so much fluid that you refill too often, 2.2 liters won't do much for you either.
Old Aug 23, 2012 | 03:21 PM
JTRADAR61's Avatar
I guess what I should have asked if anyone knows if the US models have the connections in the wiring harness for the low fluid light/message.
I live in the northeast and in the winter the roads are salted fequently. Washer fluid gets used like fuel. And when you run out its not fun. Acura should have it on its US models as most all cars do today.
Old Aug 23, 2012 | 03:39 PM
musty hustla's Avatar
Interesting question...I would imagine that the connections are there. The problem will be locating them.
Old Aug 23, 2012 | 04:20 PM
tsx_consultant's Avatar
Wait the MIS doesn't say when the washer fluid is running low?
Seriously??
Old Aug 23, 2012 | 06:10 PM
iSeeYouTwo's Avatar
I don't think he's confirming that the MIL doesn't say it, I believe he's asking.
Old Aug 23, 2012 | 11:15 PM
kixo's Avatar
At least for 2011 U.S. models, the MID doesn't indicate low washer fluid.
For the small cost of a larger tank and a wiring harness, you'd think that Acura would just equalize the U.S. specs with the Canadian model.
Maybe it's to save about 5 pounds of carrying weight.
joflewbyu2
Oct 8, 2015 11:16 AM
STL TL-S
Sep 23, 2015 08:52 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
max4swag
Sep 14, 2015 07:55 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
