TPMS/Headlight
Old Jul 27, 2008 | 10:34 PM
daredevil0610's Avatar
ACUREVER!!!!
TPMS/Headlight
First of all I'm happy to be part of TSX family. Just bought '09 TSX Grigio w/o tech. last Thursday. I installed my old rims to the TSX. Now I have a TPMS in my dash. Do you think I need to inflate it more? How About the headlight or parklight that is being on all the time? Can I turn it off. I read the manual about daylight sensor thing but I don't know if you can turn it off. Thanks Guys in Advance!!!!
Once again very proud to be a TSX family and TL family!!!!
Old Jul 27, 2008 | 10:41 PM
thunderbt3's Avatar
The car isnt detecting the TPMS sensors, thats why its throwing the light. You need to have the sensors installed or you need to rig a way to have them in the car showing the correct pressure to turn the light off
Old Jul 27, 2008 | 11:58 PM
ill45's Avatar
Lets see some pics of your car with the new shoes!
Old Jul 28, 2008 | 12:04 AM
ACUREVER!!!!
Sorry, just installed the old shoes from old TL this afternoon but I will try to shoot better ones tomorrow.
Old Jul 28, 2008 | 12:27 AM
ACUREVER!!!!
Here's the shoes where it came from. I swap the shoes and I'll take a pic. if I have time maybe this weekend so swamp at work.
https://acurazine.com/forums/showthread.php?t=146248
Old Jul 28, 2008 | 01:51 AM
user 3478964's Avatar
You have eliminated your car's TPMS by changing the wheels. The sensors were in the stock wheels you jettisoned. They were mounted inside the tire behind the valve stem. The system only works with TPMS specific wheels, so it is unknown whether new sensors can be installed in your aftermarket wheels. If not, you will always have the TPMS warning.
The lights that are on all the time are the daylight running lights. There is no way to defeat this feature save for pulling the fuse for them, but I wouldn't recommend doing that because God knows what else doing so will also deactivate.
Old Jul 28, 2008 | 12:20 PM
davidspalding's Avatar
Make a hole, coming thru!
... How About the headlight or parklight that is being on all the time? Can I turn it off. I read the manual about daylight sensor thing but I don't know if you can turn it off. ...
again ... there are DRLs (daytime running lights) in addition to the OFF/ON/AUTO feature for nighttime headlights. I believe the high beam bulbs are operated at half-intensity for DRLs.
(As a side note, I wonder if the AUTO goes on in short underpasses/tunnels. Since HIDs are worn out by the number of times they're turned on -- 3000 or so per lifetime IIRC -- momentary on/off like flashing your headlights or passing through tunnels could shorten their lifespan a wee bit.)
Old Jul 28, 2008 | 12:52 PM
They do go on in short underpasses and tunnels. If that's a concern for you, there are two options: turn off the auto function, or reduce the sensitivity of the light sensor using the lighting settings menu in the MID. Assuming your 3000 turn-on lifespan is accurate, the HID's would last over 8 years assuming one turn-on per day, every day. That's not bad.
Old Jul 28, 2008 | 02:30 PM
Tapwave's Avatar
Trill
what size rims are those?
Old Jul 28, 2008 | 04:45 PM
2009TSX's Avatar
The Anti Avatar
Actually, I noticed that on my drive home from work (which is right around twilight) that my sensor lights do go on and off under the darkened underpasses. Its one of those things that I find slightly annoying however, I can't blame the car or sensor because of the little amount of light left during my drive home.
As long as my bulbs will lost me over 3yrs I'll be happy!
Old Jul 28, 2008 | 06:01 PM
patcracks's Avatar
3000 turn on? whered that come from? is that true?
Old Jul 28, 2008 | 10:07 PM
ACUREVER!!!!
18' rims but I think 19's will be better.
Old Jul 29, 2008 | 09:41 AM
Originally Posted by patcracks
3000 turn on? where'd that come from? is that true?
It's a very, very rough guesstimate that was bandied about in another thread. YMMVAPW.
What I've read (here) is that the "ignition" of the HID light is what ages it, not the hours that it's illuminated.
Old Jul 29, 2008 | 06:34 PM
patcracks's Avatar
true that, the ignition part is pimp on the tsx!
Old Jul 29, 2008 | 06:55 PM
mskchui's Avatar
i wonder if anyone knows how to change the all the lights to HID.
Old Aug 1, 2008 | 10:00 AM
wspy's Avatar
2008 Acura RDX
Pulling the fuse for the DRL will not affect anything else other than the lights. Therefore if you do not like the DRLs just pull the fuse. Thats what i did on my RDX!!
Old Aug 1, 2008 | 08:44 PM
Ethical quandary of the week: if you pull the fuse for them, do you tell your insurance co. that you disabled the DRLs?
Old Aug 1, 2008 | 08:54 PM
09TSX's Avatar
I think one should, they might say its irrelevant to them, but in the case that you would be involved in an accident and the DRL were de-activated, they might deny the claim and then what?! I'd feel more comfortable telling them, and to be honest, I'd rather have my DRL on all the time, we have them here in Canada for a long time and its just so much better to see on coming cars from way far during the day time....
Old Aug 1, 2008 | 09:23 PM
Colin's Avatar
David, OT but... your new avatar is CLASSIC
Old Aug 3, 2008 | 10:33 AM
It's a safety feature, why someone would want to disable them kinda stumps me. Would you disable the airbags as well, because if they deploy the car might be a write-off?
Thanks. "Internet Explorer, bah! Why doncha use a REAL web browser!"
