RUST/Oxidation in engine bay??? ***PICS
Old Aug 15, 2015 | 11:51 AM
tastytreats's Avatar
Hi all,
I have a 2010 I-4 (bought in 09) 43K miles. Today I decided to assess my engine bay for cleaning. I check my fluid levels every 1-2 weeks. However, I just don't have the expertise for cleaning the engine bay. So today I wanted to take a closer look to see what was needed.
Also, additional info: I park my car outside when I'm at home. At work, 90% of the time the car is in a garage. It's my daily driver so its been though all the elements.
I found corrosion on the aluminum and bolts (pretty sure this is normal as I have seen this on other cars that are not cleaned regularly). Its a thin white power type of residue.
Now, to the weird part. I look down to where the lower engine mount is (below the radiator). I find what looks to be RUST on a couple welds and some of the bolts down there. Is this normal??? have any of you seen this before?
I took pics, hopefully I posted them correctly and u all can see them. (first pic is of the aluminum corrosion) Any help would be much appreciated
Attached Thumbnails RUST/Oxidation in engine bay??? ***PICS-20150815_110516_zps79ovpkcn.jpg   RUST/Oxidation in engine bay??? ***PICS-20150815_110436_zpsae5xjv4c.jpg   RUST/Oxidation in engine bay??? ***PICS-20150815_110446_zpsrdk5mywm.jpg   RUST/Oxidation in engine bay??? ***PICS-20150815_110452_zpsoo2gzz2h.jpg   RUST/Oxidation in engine bay??? ***PICS-20150815_110524_zpsmdgoj7xg.jpg
Old Aug 15, 2015 | 03:31 PM
ulrblitzer's Avatar
<p>I would say a lot of that is moisture and dirt build up, specially in pictures #1, #3, &amp; #4. Try just wiping that off with some cleaner and towel.</p><p>As for rust on the weld and bolts, I have that too. The previous owner ran the car without the undercarriage tray for who knows how long, so I associate the rust to that. Living in the Midwest also adds to rust build up. I've been meaning to take a wire brush and sand paper to clean mine up, then touch it up with some spray paint.</p>
Old Aug 15, 2015 | 06:01 PM
cu2wagon's Avatar
I don't see anything terribly out of sorts for a 5ish year old car. If you live in a moist environment, that's just a part of life.
Old Aug 17, 2015 | 09:17 AM
alexb92's Avatar
Perfectly normal...
Old Aug 17, 2015 | 02:20 PM
iSeeYouTwo's Avatar
<p>Junk it</p>
Old Aug 17, 2015 | 02:25 PM
Shoulda gotten a BMW, I heard those things don't rust..
Old Aug 17, 2015 | 02:39 PM
BROlando's Avatar
I saw on the news today that metal will rust in the presence of oxygen and chlorine that is catalyzed by water.
Old Aug 17, 2015 | 10:10 PM
rofl thanks for the replies! I'll definitely look into using a wire brush/sandpaper for the rust on the welds at the bottom. As this was my main concern.
Old Aug 17, 2015 | 10:24 PM
cu2wagon's Avatar
If it's only superficial surface corrosion, you might be best just leaving it alone. Whatever you do clean off you should protect afterwards with a prime and paint. Otherwise it'll just keep oxidizing and if you keep cleaning it, given enough time it'll all return to the earth elementally.
Old Aug 18, 2015 | 05:38 AM
xtcnrice's Avatar
VTEC just kicked in, yo!
<p>yep.. no point unless you coat the affected areas with high temp paint or something after sanding it all down. Else it'll all come back.</p>
Old Aug 18, 2015 | 08:21 AM
BROlando's Avatar
POR-15 is a product you may look into.
SidhuSaaB
May 30, 2020 12:40 AM
Aug 15, 2019 12:58 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
