Replace DRL with LED TSX
Old Sep 5, 2012 | 11:32 AM
ojasdatt's Avatar
2009 TSX
I am going to replace my day time running lights (Acura TSX 2009) HB3 9005 with the led's below.
Would it be an issue ?
http://www.superbrightleds.com/morei...d-product/149/
Old Sep 5, 2012 | 12:09 PM
DLCU2's Avatar
From what I read, you lose the ability to high beam
Old Sep 5, 2012 | 12:14 PM
ssjoeboe9's Avatar
ROTAREDOM
not sure what ur going for, but if you just dont want the DRL to be on but still want your high beams just pull the fuse.
Old Sep 5, 2012 | 12:26 PM
mrstak's Avatar
7# werC 2uoYeeS
maybe he wants the pure white drl look? but yea you'd lose your high beam function
Old Sep 5, 2012 | 12:37 PM
ojasdatt's Avatar
2009 TSX
Yeah i am going for the white look. Would i get a DRL error on my dashboard ?
Old Sep 5, 2012 | 12:51 PM
mrstak's Avatar
7# werC 2uoYeeS
yes. you will need resistors to get rid of the error...
all this is searchable information btw
Old Sep 5, 2012 | 01:03 PM
robpp's Avatar
Graphite Ghost
i have LED DRLs.
you need a set of resistors....iJDMtoy sells some. search on acura on that site.
FYI: the tsx turns down the volts on the high beam for the drl. that means your LEDs will also get that amount of voltage. it all works. the issue I had was I wasnt happy with the output of the LEDs in bright sun at 6 volts. couldnt see them.
i added a vleds drl module that makes the 6 volts back to 12 volts. had to add a relay to make it all happy.
and to offset the lack of high beams I put HIDs in my fogs and those are now my high beams when i need them. and to be clear...i have a Hi Beam light its just a LED that isnt nearly as bright as a normal high beam.
Old Sep 5, 2012 | 01:08 PM
ojasdatt's Avatar
2009 TSX
thx a ton everyone
Old Sep 5, 2012 | 04:07 PM
SlickxAc's Avatar
Originally Posted by robpp
i have LED DRLs.
lol i bought my led DRL from ijdmtoy and i think they were being nice or something cuz they just gave me the resistors for like free or do they come with it? idk cuz i went to the actual shop to buy it since it was like half a mile from my house xD.
Old Sep 5, 2012 | 04:15 PM
BonB's Avatar
5th Gear
i have LED DRLs.
Can you post some pictures of how it looks when you get a chance?
Thanks!
Old Sep 5, 2012 | 04:42 PM
robpp's Avatar
Graphite Ghost
^^^^^^^^^^^^ pics here
https://acurazine.com/forums/showpos...&postcount=107
Old Sep 5, 2012 | 07:41 PM
civichbdx's Avatar
Hey robpp!
Can You Still Flash To Pass after moduel install??
Old Sep 5, 2012 | 08:27 PM
robpp's Avatar
Graphite Ghost
yes I can flash to pass and I can put the high beams on. before the relay was in, flash to pass popped the high beam fuse. once I seperated them with relay its all good.
Old Sep 6, 2012 | 10:09 AM
DUBSPORTN's Avatar
I still want my highbeams but want to lose the drl
what fuse do I pull to disable the drl
Old Sep 6, 2012 | 10:12 AM
mrstak's Avatar
7# werC 2uoYeeS
and use the search function.
Old Sep 7, 2012 | 11:31 AM
ojasdatt's Avatar
2009 TSX
i have LED DRLs.
Do using resistor cause overall harm to the wires or to the car. I don't want to risk burning any wires.
Thx
Old Sep 7, 2012 | 11:36 AM
mrstak's Avatar
7# werC 2uoYeeS
no
cycdaniel
Dec 17, 2019 10:58 AM
sockr1
Oct 1, 2015 01:31 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
