removing trunklid badges
Old Apr 16, 2010 | 10:41 AM
klassic1's Avatar
picking up my 2010 TSX this weekend and want to know if the decklid badges are held on only with sticky tape or if there are also positioning pins behind them. Dont want to pull off the badge and find a hole. Want to remove word "Acura" and "TSX" from the trunk. Let me know if you know. Tks.
Old Apr 16, 2010 | 11:10 AM
thunderbt3's Avatar
Acura and TSX are just held on with tape, the A symbol has tape and pins
Old Apr 16, 2010 | 11:20 AM
Luchin's Avatar
The Acura and TSX badges are held on with double sided tape and are very easy to take off. I did it with dental floss by 'sawing' back and forth behind the letters. I'm not sure where you live but if it's warm enough, parking the car in the sun will soften the tape enough to make removal very easy. A hair dryer works as well.
You may want to double up on the dental floss as it does break if you try to use a single strand. If you have fishing line, you're laughing.
It is likely that there will be some double sided tape left on the paint. I used the ball of my thumb to role it off and then used a wax remover and went over the area to make sure all the residue was gone. I then used some mild polish, or wax with cleaner in it will work, to make everything look uniform.
Old Apr 16, 2010 | 12:17 PM
acuratsx2010's Avatar
I've used this chemical similar to Goo Gone but safe for vehicles on the letters and let it penetrate the tape then used a rubber spatula to remove the letter off. Make sure you spray the stuff onto the spatula too. I got the stuff from a home improvement store in the paint department. The letters just popped off and didn't scratch my paint either.
Old Apr 17, 2010 | 10:49 AM
james_and7's Avatar
I waited for a hot summer day then ripped them off with my fingers. Worked like a charm.
Old Apr 17, 2010 | 09:38 PM
bembol's Avatar
We got our '10 Base and the night it got delivered I was able to remove "ACURA" with my fingers, no issue and then polished it with Meguiar's. I wanted to take off "TSX" but my brother said no.
Old Apr 18, 2010 | 04:40 PM
klassic1's Avatar
thanks to all- will be pulling off the letters the first chance I get- dental floss and hair dryer in hand.
Old Apr 18, 2010 | 10:41 PM
defconskylude's Avatar
use a heat gun and goo gone
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
AJRozsa
Oct 5, 2015 07:50 PM
lowgrowl
Sep 26, 2015 05:18 PM
