remove trunk light wagon?
i can only give a suggestion, as i havent really explored the inside of the wagon. you can get a small flat head, and just put it right at the gap of where the clear cover is, and gently pry it up from both sides, should pop out. does the vent to the left of the light or whatever that hatch to the right pop out?
I would stay away from screwdrivers and use a trim tool. You can get a set fairly inexpensively from Harbor Freight or any auto parts store - like this one from Autozone.
thanks ceb. I have a much larger set than that, unfortunately nothing is really fine enough to remove the other lenses but now that i am stuck I may try the finest one I have on the hatch light/
i used a jewelers type blade to remove all my other lenses as I didnt have a plastic tool that small that i trusted.
i cant ever remember seeing anything plastic small enough and tough enough that it wont break that you could pop the visor lenses off??
exactly how I did all the rest, i called it a jewelers screwdriver you call it eyeglasses, i have a set of about 6 in a small case, it even tells youi the size LOL
since Ceb suggested plastic I assume for all the lenses I was asking if he knows of some plastic tools that are small enough.
BUT ALL THE REST are done thanks to some searches on here. a review of the exleds and a few pics should be up a bit later.
i just need some NERVE to pry that rear one.......someone suggested i look under that access point so I will look at that later today too.
I actually had a very small one that was metal coated in plastic - about as thin as a jewelers screwdriver but a lot wider. I bought it years ago at Radio Shack but they are long gone now.
I suspect you could pop off that little access panel and get to the light through there.
Do you have a good enough relationship with your dealer to ask?
tonight i will look at that access panel.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
