Many warning lights after bad coil that won't go away
Strange issue with my wife's 2011 TSX. It left her stranded and was basically in limp mode with TSA, Emissions, Transmission, ABS lights all going crazy and a bad misfire. I figured out it just had a bad coil, put a new coil in it and now it runs great except it still has "Check Emissions System", "Check Brake System", "Check Transmission", "Check TSA System" warnings and the ABS light on. I cleared the engine misfire codes with a scanner and also unhooked the battery for a couple hours but the lights/warnings remain. (Check engine light went out) Any ideas? Anybody else run into this issue? I don't know how a bad coil would have caused all of this.
Please share with the class @dragstang86 , inquiring minds would like to know
Lakerfan4life23
05-05-2017 11:58 PM
