Annoying check engine light and VSA and /!\ lights
Old May 5, 2017 | 11:25 PM
Lakerfan4life23's Avatar
Recently my check engine light came one early morning on my way to work. The engine shook a bit and I gave it gas and it seemed not to go very far as if the gas pedal was not being pushed. THe codes I got werr P0131 and P0132. I used the OBD II reader to get the codes. I erased the check engine light , drove the car and within 60 seconds the check engine light came on along with the VSA and /!\ lights. I used the OBD II again and only got a P0131 code. The P0132 code has not come up any more. I have changed the bank 1 sensor 1 O2 oxygen sensor 2 times already so I know the actual sensor is not the problem. What Gives? any thoughts or tips would be greatly appreciated. Thank you!!!
Old May 5, 2017 | 11:58 PM
TacoBello's Avatar
The vsa and ! Lights are likely related to your brake fluid. Check the brake reservoir to see where it is at.
I had the same happen after I bled my brakes and left one of the brake caliper nipple valves just a wee bit open... took several days before the fluid came down enough for the lights to come on
Same thing though... lights would come on 60 sec after driving.
Dante Joseph
May 6, 2017 08:32 PM
Namelesstl
May 3, 2017 06:38 AM
Carfixr
May 1, 2017 02:17 PM
Supaman
Apr 14, 2017 08:23 PM
