ABS and TCS lights on
Old Nov 27, 2008 | 02:18 PM
Rajca's Avatar
wham bam thank you ma'am
on my 03tl-p, a while back some how they RF wheel sensor wires got cut or ripped, i soldered them and it was all good. now a couple days ago while driving both lights came on (while the car is on, the lights are off, once you move they turn on). i check all wires and connections and one got loose, i re-soldered it, put heat wrap on it and liquid electrical tape, and for peace of mind put regular electrical tape on it. now the light just stays on all the time. i unplugged the battery and pulled the clock back up fuse and the lights are still on.
anything i might have missed?
Old Nov 27, 2008 | 04:07 PM
death's Avatar
Umm, that usually means your tranny is shot. Do you notice it's slipping at all (engaging reverse and shifting through 2-3)? I would also take it to Autozone and have the codes run.
Old Nov 27, 2008 | 05:45 PM
Rajca's Avatar
trans is good, the check engine light would be on and i never saw the d5 light blink. i baby this car unlike my 02tl-s. auto zone only check the check engine lights, not the abs or tcs
Old Nov 27, 2008 | 08:40 PM
6MTUA5's Avatar
No He Can't
You can only run the codes if it is throwing any, which isn't the case here.
Old Nov 27, 2008 | 11:55 PM
fsttyms1's Avatar
I would say replace the sensor/wire. There has to be something wrong with it to be causing it.
Old Nov 28, 2008 | 07:05 AM
Rajca's Avatar
ok, ill try that.
Old Nov 28, 2008 | 09:04 AM
01tl4tl's Avatar
agree with kris
If you ripped the wire apart once, then fixed twice, its probably bad down inside the main attachment point. On another car I had rust inside the connection at the wheel.
Sometimes you have to replace damaged parts with new ones~
Note- trans failure does not require a d5 light or others to occur
Note2- zone and other places can pull codes- not just engine codes
Whatever info the computer is holding- it should tell a machine!!
Old Nov 30, 2008 | 11:35 AM
Rajca's Avatar
ive looked here
http://www.acuraautomotiveparts.org/...catdisplay.jsp
and couldnt find the sensor i need.
Old Oct 30, 2009 | 04:42 PM
webmastir's Avatar
2003 TL
ABS & TCS lights are on. think wheel speed sensor was knocked loose. how much do those usually cost?
error codes are:
1301
3102
'Front Left wheel speed sensor'
autozone quoted me 250 fucking dollars?!?!?
is that normal?
i know for sure it's the speed sensor, but i'm just wondering if it's just more of an annoyance at the present time than an actual danger..?
Old Oct 31, 2009 | 01:58 AM
01tl4tl's Avatar
speed sensor controls abs/tcs which are semi important
May screw up the cruise control too
Check with auto recyclers for a good used one
Call more places! Search online
got to be careful doing brakes- or tear out the sensor lead wires
Old Oct 31, 2009 | 10:56 PM
webmastir's Avatar
2003 TL
ok. thanks
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
