how do I paint my calipers?
Scene it done, heard it's easy, but have never tried it. Im referring to the front but traditionally do you paint all four? I want to paint them red like wannabe brembo
, im assuming i just remove them, separate metal parts, degrease, and paint with some high temp paint?
i tried search but only found a thread bashing modesto so please have mercy! lol
does acura have nicer stock calipers for the tsx (v6) like the ones that say 'acura' on it?
this dude in another forum just used painters tape to tape off the parts, is this an ok method
thanks all!
, im assuming i just remove them, separate metal parts, degrease, and paint with some high temp paint?i tried search but only found a thread bashing modesto so please have mercy! lol
thanks all!
you could remove the caliper and do it or you can be like me and just get a brake caliper spray paint (i chose black, since I used to have red on my old car and was just ricey imo) used painter's plastic to shield off the fender area and rotors. used tiny crumbled pieces of paper and also painters tape to shield off the brake pads and parts of the brake i didn't want to paint. Cleaned with degreaser and soap and water.
and just did many coats of paint with the rattle can (first coat will be thicker) and then wait 20 mins, spray again etc. I did this for about 4 hours since I had time and a garage. I left it overnight to dry but it was pretty much dry within coats already.
the ones that say 'acura' on it is the 3G TL-Type S model and I I believe the previous gen RL had it too
they sell those decals here
http://www.jvdgraphics.com/prod-cs%20Acura.htm
let me know how it goes! i might want to try this someday. with black paint and white decal.
here is my thread you can see front and back painted
https://acurazine.com/forums/showthr...=792220&page=2
i think ill also need to buy another jack because the one i have is walmart-good-for-3000lbs
i just..dont feel safe with it, so i shove my heavy-duty tool bin under my car when i do work
haha those look slick, but vinyl on a caliper?? i dunno man i think ill just paint mine. ill post pics!
good luck man, cant wait to see your results
It doesnt dry that fast and I agree that its a better way
i was thinking about getting srings too for next mod but not sure how the stock struts will hold up.
taping is the hardest part
painting is fun and result is great
being proud of doing yourself PRICELESS
There are people here with more then 10k miles on springs and problem free
I have 4k miles on Eibach no problem also
on my previous car, i used caliper paint but didn't prep well so it started chipping off after a few thousand miles. Even with a spray can, you could do a good job its all about the prepping.
Yeah as for springs, I've been on S-techs over 40K and still no issues
How would the fake Brembo covers look over the calipers instead of painting them? Is there a safety risk in putting them on?
Do you guys think that painting the Calipers Red on my Milano Red G2 would look any good or is that too much red?
too much IMO, but that's only imagining it in my head. it might look surprisingly well
I (with ecko508) painted my 2011 calipers black AND added the white Acura decals. I highly recommend you do it slowly but it will look awesome. Especially if you have aftermarket rims where you can see through the spokes easier than the stock ones.
Here is mine:
Matt
Here is mine:
Matt
If you're painting your calipers, it's really easy to remove the caliper and brake shoes to make the job much better looking, and it only takes an extra 10 minutes per corner. It's generally two bolts that hold the caliper on, remove the claiper, then the pads will pop out. Don't stretch or twist up your brake line, or step on the brake pedal...
Most people will just paint the entire caliper without masking off the pads or removing them - with a little more time invested it will look OEM (as long as you don't paint them red or yellow).
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
