Fog light install problem
I attempted to replace my fog light bulbs using the manual as a guide. I was able to remove the three clips but the cover does not open like shown.
I don't want to force the plastic guard to open but it also looks like the inner wheel well it part of this system. There's also three bolts holding the under skid protection in place. Do I need to remove all of this stuff to replace the fogs lights?
It's a 2012 TSX Special Edition with the ground effects. Could that be interfering with the removal process?
I popped the three clips and pushed the access panel up and in. You can read some trials and tribulations here:
https://acurazine.com/forums/photogr.../#post15605318
I tried pushing the door in then out and even took out more clips that I thought was preventing the door from swinging open. It seems that the front body skirts/ground effects are blocking entry to the fog light access.
What do I need to remove in order to access the fog lights in the special edition?
circled part is the fog light door where it meets the front lip. It won't swing down.
ulrblitzer (03-16-2016)
Should be one or two bolts in each of the wheel well, 2 or 3 on the top, a bunch of "bitch" clips aka bumper clips.. from the right and left pull away (to right and left respectively) just under the headlight, pull straight away from the car/headlights to unclip it. Grab the bumper from the top and 'unhinge' it off the radiator support.
done.
done.
A moderator really needs to sticky this link for the CU2.
The following 3 users liked this post by ulrblitzer:
Many thanks, urlblitzer. Was going to post about any tips for removing front bumper, but this may be all the help I need.
Have to replace a broken fog light. It's already getting pretty warm in Phoenix, so, I better get off the couch and get this done before its too hot.
Skier4lyfe303
07-13-2016 03:53 PM
wirelessnate
2G TSX Problems & Fixes
03-11-2016 01:23 PM
SupremeOpinion
02-08-2016 06:16 PM
