Do you really need to switch to synthetic oil?
My 3 month old TSX is sitting at 40% oil life. Is synthetic oil worth it? I never go past 4k RPM. Is it recommended or can I just get away with regular oil. I plan on keeping this car forever.
it's a car-drive it
From personal experience-I just use regular oil. I think just having oil changes is the benefit. My 06 tsx, bought new, will be 4 years old 11/17. It now has almost 115,000 problem free miles. I do mostly highway driving.
^ +1
Of course, you can switch if you'd like, but there's no need to if you don't want to.
No need for synthetic oil if you change your oil on a regular basis.
My last car was a 90 Civic Si with over 260K miles on it, regular oil change @ 4000-5000 miles interval.
Synthetic oil is more stable and last longer than conventional oil, however, your maintenance minder wouldn't know the difference and will inform you to have an oil change at the regular interval.
^^ Also, many feel that synthetic should not be used too soon. Our lead tech recommends 10K to insure proper break in. Overkill? Probably, but better safe than sorry... especially when you're going to deviate from what the manual suggests.
Stick with regular oil and keep up with the maintenance and you should be just fine. I had 6.5 years and 70k miles on my 04 TSX using regular oil, before trading last month. The car was running great.
Summer is Coming
I switched after 10K but didn't really see much difference. Maybe a perceived difference. My 2000 BMW had synthetic and it only required changing at 15k. And the oil still looked new.
For more than any human being possibly needs to know about oil....
http://www.bobistheoilguy.com/cms/
beware, you can waste a lot of time there.
Some cars require synthetic. My 05 passat required it. If you don't use synthetic it will burn oil and kill the engine. Now with the TSX I would ONLY use synthetic if the manual says so but if it doesn't than using either one wont make a difference.
I park my car outside in a cold-weather state, and I use Mobil 1. Cold starts in winter will wear out your engine if you just use regular oil. I change the oil every 5k miles.
From that noted automobile authority, Yahoo:
•Better low temperature performance. Synthetics flow freely at subzero temperatures, pouring easily at -40 or -50 degrees F. where ordinary oils turn to molasses. This makes for easier cold starts and provides faster upper valvetrain lubrication during the first critical moments when most engine wear occurs.
http://autos.yahoo.com/maintain/repa...ques120_1.html
From Wikipedia:
Advantages
The technical advantages of synthetic motor oils include:[citation needed]
The disadvantages of synthetic motor oils include
I consider my driving style extreme (in my Z) so thats why i use it.
Advantages
- Measurably better low and high temperature viscosity performance
- Better chemical & shear stability
- Decreased evaporative loss
- Resistance to oxidation, thermal breakdown and oil sludge problems
- Extended drain intervals with the environmental benefit of less oil waste.
- Improved fuel economy in certain engine configurations.
- Better lubrication on cold starts
- Longer engine life
- The lower friction may make them unsuitable for break-in (i.e. the initial run-in period of the vehicle) where friction is desirable to cause wear. Improved engine part machining has made break-in less critical than it once was, though. Many modern cars now come with synthetic oil as a factory fill.
- Potential decomposition problems in certain chemical environments (industrial use dominantly)
- Potential stress cracking of plastic components like POM (polyoxymethylene) in the presence of PAOs (polyalphaolefins).
- Synthetics do not hold lead in suspension as well as mineral oil, thus caution is advised when the engine is run on leaded fuel.[citation needed] As an example, leaded fuel is still commonly used in aviation (avgas).[17]
- In July 1996, Consumer Reports published the results of a two year motor oil test involving a fleet of 75 New York taxi cabs and found no noticeable advantage of synthetic oil over regular mineral oil.[18] In their article, they noted that "Big-city cabs don't see many cold start-ups or long periods of high speed driving in extreme heat. But our test results relate to the most common type of severe service — stop-and-go city driving." According to their study, synthetic oil is "worth considering for extreme driving conditions: high ambient temperatures and high engine load, or very cold temperatures." [19]
- Synthetic oils are not recommended in automotive rotary engines.[20]
Here's another reference, from Canadian Driver:
Vehicles subjected to Canada’s cold winter starts experience more engine wear in a couple years than a California vehicle may in a couple decades of starts. Fuel injection has helped, but we can also do things to reduce engine wear. Use the right oil, plug in block heaters before cold starts, and drive with a light throttle until the oil is warm and lubricating well.
http://www.canadiandriver.com/2003/0...ld-weather.htm
Since I stomp all over my TSX I only use synthetic. Yes, you can use regular faithfully. I wouldn't say anything against it. But there are advantages to using synthetic. Besides, if you buy a car like this, you should treat it well... Not just getting by. Also citing a post above, the tolerance and machining on these cars are so close I can't imagine any negative impacts from the use of synthetic at the first oil change. Does it say 10k in the manual? I don't remember seeing that.
i personally feel like regular oil has come such a long way compared to maybe 10 years ago. same is true for synthetic. but why im saying this is that reg motor oil is so good, if the car doesnt require synthetic, i would say there is no need to throw your money into something that may not provide you with any additional benefit
Also, nice signature :P
I'm a new member and new Acura owner that found this site very helpful. I wanted to make everyone here aware, especially new Acura owners, that when you buy a car from Acura the dealer is advising that you MUST use synthetic oil. They want to sell you a maintenance package that offers offers this service at a discount, if you use synthetic oil this is a good value. The problem is the car does not require synthetic oil. I am referring to the TL.
it's a car-drive it
The Acura dealer in Tampa, fl. I am a new acura owner so I wanted to buy from a reputable dealer. I am surprised they are advising this. I initially bought the package and am looking for a full refund from them.
He was speeding, Rusty!
My dealer included free oil changes for 4 years and they use the synthetic that the owner's manual states to use. I'm fine with that, free is a good price and of course they give it a nice wash before returning it...
I was at the dealer in December and had the Schedule B done and I'm fairly certain they just used regular oil.
It's 4 years/50,000 miles. They aren't the closer dealer to my house, but they're pretty close to work and have a decent loaner car/pick up drop off policy.
WTH happened to my garage
Florida Hwy Patrol 5.0, bought 3 yrs old w/65k miles. Drove it 12 years & 50k miles...a Quarter Mile at at time. =)
Tore it down to install GT40 heads, the cylinders & lifter valley area was like brand...new.
Mobil1
Mobil1
My 2011 I-4 wagon specifies 0W-20. I've never seen that viscosity in dino oil - just synthetic. I just use Mobile 1. That being said, a good grade of regular oil would be OK if you just change it often. I'll just stay with the synthetic 0W-20 that is specified - should help the cold starts.
http://www.honda.ca/parts-accessorie...oil-and-fluids
Maybe I just get this way from waking up on top of a gigantic pile of cash, but I generally see the cost difference between regular oil and synthetic oil as negligible. Considering we're talking a car you're planning on keeping forever, why not treat it like you love it?
musty hustla (01-18-2012)
Карты убийцы
I've said this before in one of the million oil posts. My friend did his thesis at RPI on oil breakdown. Even crappy Quakerstate was good for about 11,000 miles. But when it started to breakdown, it happen quick... like 500 miles.
Syn is good for 15000 miles without question. Even with the higher price of syn, you'll come out much better over time.
That's because Honda 0W-20 engine oil is a full synthetic formula.
--Mickey
David_Dude
Looks like the 0W 20 is really quite new.
You don't need to go with a synthetic- especially if you're in the camp of changing the oil every 3-5K miles. That interval is likely to be a waste with a conventional oil and a large waste with synthetic.
I go with a synthetic because of the added life it offers and the fact that it sticks better so those cold starts get less wear/tear than a conventional gives before getting to full oil pressure. I follow the MID for change intervals and am comforted in knowing that I can go to 0% with no concerns using a synthetic if I want to. I usually chicken out and change it in the <5% range.
One economical compromise is to go with a Synthetic Blend (Motorcraft is highly regarded) which gives you many of the benefits of a full synthetic with a price break. You can get Motorcraft at Walmart. Don't skimp about changing the filter each time- I personally use Purolator which beats Honda's Fram-based filters and is often on sale.
The other thing I do is place a couple of magnets on the filter too. I cut a filter open and sure enough there was a little metallic crap hanging by the magnet.
IBankMouse
06-13-2020 12:53 PM
lanechanger
10-13-2015 10:56 AM
xsilverhawkx
09-28-2015 06:51 PM
