Backup Camera Install - Reverse Wire
Old Sep 24, 2016 | 04:21 PM
GameOver69's Avatar
Where can i find the reverse wire so that i can tap into it for my backup camera install. I assume i can find it somewhere up front, without having to wire all the way to the actual tail light? Any detailed assistance would be appreciated.
Old Sep 25, 2016 | 11:57 AM
jumpSMASH's Avatar
If you're an automatic, you can remove the center console and expose the shifter control switch. Switch will have individual solder points and reverse would be second from top. Just follow that line
Old Sep 26, 2016 | 07:49 AM
opboarding's Avatar
Hello World
I just wired my aftermarket camera to the reverse light inside the trunk. It's not too difficult to run another wire back there along side the reverse camera input wires.
Old Sep 26, 2016 | 07:51 AM
D4nnyD's Avatar
U can use splice the positive wire from the reverse light... i used that for camera power and reverse signal. you need to run the camera signal aux to the head unit anyways, so running this cable down the car is pretty simple if you do them together.
Old Sep 26, 2016 | 08:15 AM
icu2tsx's Avatar
X2
I also used reverse light.
Old Sep 27, 2016 | 10:53 AM
GameOver69's Avatar
i found it. i just tapped into the reverse wire. Its a light blue wire, and i used the one that was under the driver side door hard plastic. worked out great
AmplifiedDetails
14
May 5, 2023 12:16 PM
OnlyDaanish
Mar 24, 2018 09:17 PM
Beau Reynolds
Oct 18, 2016 07:59 AM
shazi00
Oct 10, 2016 12:27 PM
txfun
Jul 10, 2016 04:30 PM
