2G TSX Chat, Chit, and General Info Thread
Old 02-23-2015, 08:54 PM
  #18641
Received 16,263 Likes on 11,973 Posts
Originally Posted by VR1
Well back to the dealer she goes. So far I've had a problem like once every 2-3 months with this damn car.. Only 20k miles now, can only imagine what happens after 100k. Love the car but its been a headache with all the problems.
not to be an asshole...(okay, im an asshole)
butt, LOL.
you dont have any problems sir.
a noise might be disconcerting, but its nothing to be alarmed over.
you're not going to die and your car isnt going to fall apart.
The following 5 users liked this post by justnspace:
Harper (02-23-2015), MC MiYoung3269 (02-24-2015), ssjoeboe9 (02-23-2015), VR1 (02-25-2015), xtcnrice (02-23-2015)
Old 02-23-2015, 08:58 PM
  #18642
your car is gonna spend a lot of time at the dealers and all they're going to tell you is that it's normal.
Could it be that since it's cold out, your tires arent grabbing traction and you're activating ABS and or VSA?
hint, ABS and VSA make grinding noises.
Old 02-23-2015, 08:59 PM
  #18643
rawger's Avatar
Actually one annoying issue I forgot about is my drivers window makes weird noises and seems super flimsy when it's rolled down halfway.
Old 02-23-2015, 09:13 PM
  #18644
TSX AMG Type //M i-VVT
iCrap's Avatar
^ what justin said. All the dealer is gonna do is just say it's normal.
pretty sure that noise you are hearing is ABS. you said it was when you brake hard.
Old 02-24-2015, 08:34 AM
  #18645
VR1
Itz JDM y0!
VR1's Avatar
Originally Posted by rawger
What all problems have you had? I don't drive much, but *knock on wood* mine has been solid at 45k. I want new brakes and tires in the near future.
Mostly interior rattles. Dealer has replaced a bunch of pieces for me due to "warping"
Old 02-24-2015, 08:35 AM
  #18646
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
Who's on ze snapchat?
my id is "azn1221"
Old 02-24-2015, 08:38 AM
  #18647
VR1
Itz JDM y0!
VR1's Avatar
Originally Posted by cu2wagon
I could do something similar with one of my vehicles (sorry, can't remember which one. WPP, right?) under the right circumstances. Typically at low speed like bleeding of the final little bit of momentum coming to a full stop. Right before the pads would finally grip the rotor and cause it to fully stop, I could just slightly left off brake pressure so the car would keep rolling and it would start doing a low frequency groan.
The other way was starting from a dead stop with the brakes fully engaged... Let off the brakes pedal just enough to start moving and I could get it to groan.
I'm like 99% sure that was just brake pad vibration. Sounds like you're hearing it when you're on the brakes hard though.
Can you tell where the noise is coming from? Front or back? Is it consistent with applying the brakes, like it only happens while you have a certain pressure on the pedal or does it just happen briefly during constant brake pressure like it might be a rubber bushing moving and rubbing against metal?
Think it's the front. Only happens when I push down hard coming to a stop.
Old 02-24-2015, 08:39 AM
  #18648
are you losing traction when this happens?
Old 02-24-2015, 08:42 AM
  #18649
VR1
Itz JDM y0!
VR1's Avatar
No, the brakes work perfectly fine. Only happens when I push down 90% on the brakes when coming to a stop. I called the dealer and they said I'd have to come in on a weekday to have a tech ride in the car. Well I can't come in on a weekday..
Old 02-24-2015, 08:44 AM
  #18650
Mind recording a video to show what you mean?
Old 02-24-2015, 08:46 AM
  #18651
VR1
Itz JDM y0!
VR1's Avatar
Might be it but the VSA isn't engaging at the same time (light never comes on)
  #18652
VR1
Itz JDM y0!
VR1's Avatar
I'll record one today
Old 02-24-2015, 08:49 AM
  #18653
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
When you say 90%, do you mean 90% of the brake pedal travel or 90% of the effort needed to to get the pads to lock the rotors?
Hope it's not 90% travel because, damn son, that's really putting your car through a workout for day-to-day driving.
Do you feel any pulsing in the brake pedal or any vibration in the steering wheel or brake pedal?
Does it happen every time you apply the brakes? Can you get a quick cell phone video / audio clip?
Old 02-24-2015, 08:53 AM
  #18654
If you lived closer, I wouldn't mind checking it out for you, buttttttttt you're like a gajillion miles away
justnspace (02-24-2015)
Old 02-24-2015, 08:55 AM
  #18655
VR1
Itz JDM y0!
VR1's Avatar
90% travel. Like I push the pedal 90% down. I usually don't push it down that far but if I do I hear the noise. No pulsing/vibration in the pedal. Happens sometimes when I push it down hard. Will upload a video this afternoon.
Old 02-24-2015, 08:57 AM
  #18656
VR1
Itz JDM y0!
VR1's Avatar
Ya I basically live atleast a hour away from all you other Azine guys.
Old 02-24-2015, 09:00 AM
  #18657
cu2wagon's Avatar
Whoa. are you flogging it like a rented mule? That's like panic stopping.
If you're really getting on the brakes hard enough that you're almost bottoming out the pedal then it very well could be an electronic nanny stepping in. That much pressure would lock up an unassisted brake.
Old 02-24-2015, 09:07 AM
  #18658
VR1
Itz JDM y0!
VR1's Avatar
I pressed it down that hard once (was actually necessary) and heard the noise. I did it a few more times hard and I hear the noise still. I don't press it that hard in normal driving, I've just been doing it to see if I can hear the noise.
Old 02-24-2015, 09:09 AM
  #18659
cu2wagon's Avatar
Ah, that makes more sense.
My gut feeling is that, like others said, it's nothing to worry about. That's a significant amount of effort and I bet it's the nanny system trying to keep you safe.
I don't know, does the TSX have electronic brake assist?
Old 02-24-2015, 09:11 AM
  #18660
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
It's probably ABS. Just brake normally VR1
Old 02-24-2015, 09:18 AM
  #18661
cu2wagon's Avatar
And by "electronic" I guess I really meant "hydraulic". My 4Runner has hydraulic brake booster which makes much more noise than a traditional vacuum booster system. Thought that might be a player in VR1s issues.
And I don't think the TSX does, so it's all moot.
Nothing to see here. move along...
Old 02-24-2015, 03:04 PM
  #18662
VR1
Itz JDM y0!
VR1's Avatar
Did several 60-0 hard brake runs but couldn't get the sound out. I guess since my brakes were dry maybe that had something to do with it. I talk to my friend with a CL9 and he said sometimes when he stomped on the pedal when rolling to a stop he heard the same noise and was told it was ABS.
Old 02-24-2015, 04:04 PM
  #18663
iCrap's Avatar
ABS makes the exact noise you are describing so i'm pretty sure that's all you are hearing..
Old 02-24-2015, 05:14 PM
  #18664
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
We're still talking about this?
xtcnrice (02-25-2015)
Old 02-24-2015, 05:15 PM
  #18665
cu2wagon's Avatar
The following 2 users liked this post by cu2wagon:
MC MiYoung3269 (02-25-2015), ssjoeboe9 (02-25-2015)
Old 02-24-2015, 05:24 PM
  #18666
iCrap's Avatar
apparently
Old 02-24-2015, 05:25 PM
  #18667
VR1
Itz JDM y0!
VR1's Avatar
I just wanted to make sure it wasn't anything serious like warped rotors, faulty ABS, etc..
Old 02-24-2015, 05:31 PM
  #18668
cu2wagon's Avatar
At least we're not arguing over how the rear sway bar on the superior MDX works differently/the same as on the lowly TL or proletariat TSX...
The following 3 users liked this post by cu2wagon:
iCrap (02-24-2015), justnspace (02-24-2015), MC MiYoung3269 (02-25-2015)
Old 02-24-2015, 05:42 PM
  #18669
I lol'd so hard.
they have the same suspension set up we do.
hahahahhahahhahahahhahahahahha
The following 2 users liked this post by justnspace:
cu2wagon (02-25-2015), iCrap (02-24-2015)
Old 02-24-2015, 07:13 PM
  #18670
rawger's Avatar
You drive a boat, why the hell would you care about the suspension setup?
Old 02-24-2015, 08:08 PM
  #18671
^it was actually the RDX crew that were discussing about Sway bars.
I joined the convo and I guess they have a problem with me, so they started talking shit about me and the TL.
little did they know that we have the same suspension set up. hahahah
read about it here
https://acurazine.com/forums/perform...g-lqqk-925613/
cu2wagon (02-25-2015), xtcnrice (02-25-2015)
Old 02-24-2015, 08:47 PM
  #18672
rawger's Avatar
RDX is so oversteer happy too. I don't like driving my pop's RDX.
Old 02-24-2015, 11:16 PM
  #18673
iCrap's Avatar
I lol'd so hard.
lol I read that thread a while ago. That guy is a fucking retard.
The following 2 users liked this post by iCrap:
Old 02-25-2015, 12:37 AM
  #18674
xtcnrice's Avatar
read about it here
I had a bit of respect for the guy when I read part of his turbo upgrade/build. But when I came across this thread yesterday or whenever, I actually lol'd. smh.
Old 02-25-2015, 06:00 AM
  #18675
^just ego got in the way.
i understand that im not that likeable on the internet.
Old 02-25-2015, 06:33 AM
  #18676
ROTAREDOM
ssjoeboe9's Avatar
I like you...
But honestly I think 95% of your like-ability is your Avatar constantly changing to different (and ridiculous) crab gifs
The following 3 users liked this post by ssjoeboe9:
iCrap (02-25-2015), MC MiYoung3269 (02-25-2015), xtcnrice (02-25-2015)
Old 02-25-2015, 07:05 AM
  #18677
thank the mods for that! they change it for me without warning
lol
also, do you know how many PM's i get from different various members sending me crab pics?
people that ive never ever interacted with are like....Hey! saw this crab picture and thought of you.
Old 02-25-2015, 08:28 AM
  #18678
VR1
Itz JDM y0!
VR1's Avatar
Its wanna know where "crewman" came from lol
Old 02-25-2015, 08:52 AM
  #18679
iCrap's Avatar
Yeah but he didn't even do any of the work at all it looks like.
Old 02-25-2015, 09:21 AM
  #18680
ROTAREDOM
ssjoeboe9's Avatar
lol
I've been one of those people hahaha
What's the story behind that anyways? Are you friends with a MOD that changes your avatar?
Quick Reply: 2G TSX Chat, Chit, and General Info Thread
