2G TSX Chat, Chit, and General Info Thread
Old Jun 19, 2014 | 03:05 PM
  #14321
ssjoeboe9's Avatar
ROTAREDOM
Originally Posted by iSeeYouTwo
Hey guys, question.... when installing new rotors/pads.... is there anything special I need to do? I read something about a bedding process, but idk if that applies to all new rotors or what not... just don't want to mess up brand new rotors.
Yes, You want to bed the brakes in.
It literally bakes a thin layer of your pads onto the rotors and this helps with longevity/ stopping power and even wear.
I think the higher end rotors/pads even give instructions on the process.
Old Jun 19, 2014 | 03:21 PM
  #14322
opboarding's Avatar
Hello World
Originally Posted by iCrap
is his windsheild really tinted 5%? wtf?
35% with 5% strip.
My side/rear windows are 35% and sometimes I have a hard time seeing out at night and roll them down. This guy is an idiot if he thinks that his vision is fine at night.
Old Jun 19, 2014 | 05:46 PM
  #14323
robpp's Avatar
Graphite Ghost
agreed with Joe.
i go to an industrial area on the weekend. also its near a highway to go cool them off.
its a 10 hard stops; the pedal starts to fade and the farkers are smoking. then i head to the highway for a good 20 minute drive without hitting the brakes to let them cool.
Done.
most brake psd company have specific instructions online usually.
Old Jun 19, 2014 | 05:48 PM
  #14324
robpp's Avatar
Graphite Ghost
35-50 is what most do on windshield.
to each his own. i have never. but i have tinted sides and others since the mid 80's when i first saw tint. most 20%.
Old Jun 19, 2014 | 07:56 PM
  #14325
Harper's Avatar
Unregistered Member
I saw a TL today with the letters on the TL badge reversed. Acura LT Type S.
Old Jun 19, 2014 | 11:42 PM
  #14326
xtcnrice's Avatar
VTEC just kicked in, yo!
Originally Posted by opboarding
ceb would have fun with this one. Tinted windshield + tinted headlights + 10k bulbs.
https://acurazine.com/forums/showthr...1#post15053701
wow what a moron
Old Jun 20, 2014 | 09:09 AM
  #14327
mrstak's Avatar
7# werC 2uoYeeS
ryan, the guy is in the 3G TL section. enough said.
Old Jun 20, 2014 | 09:13 AM
  #14328
iSeeYouTwo's Avatar
I think I have the same rotors as you. I went with the stop tech slotted rotors and posi quiet pads.
Do you or rob have a link to the bedding process? Gonna give it a shot today when I install them.
Old Jun 20, 2014 | 10:02 AM
  #14329
robpp's Avatar
Graphite Ghost
For a typical performance brake system using street-performance pads, a series of ten partial braking events, from 60mph down to 10mph, will typically raise the temperature of the brake components sufficiently to be considered one bed-in set. Each of the ten partial braking events should achieve moderate-to-high deceleration (about 80 to 90% of the deceleration required to lock up the brakes and/or to engage the ABS), and they should be made one after the other, without allowing the brakes to cool in between.
Depending on the make-up of the pad material, the brake friction will seem to gain slightly in performance, and will then lose or fade somewhat by around the fifth stop (also about the time that a friction smell will be detectable in the passenger compartment). This does not indicate that the brakes are bedded-in. This phenomenon is known as a green fade, as it is characteristic of immature or ‘green' pads, in which the resins still need to be driven out of the pad material, at the point where the pads meet the rotors. In this circumstance, the upper temperature limit of the friction material will not yet have been reached.
As when bedding-in any set of brakes, care should be taken regarding the longer stopping distance necessary with incompletely bedded pads. This first set of stops in the bed-in process is only complete when all ten stops have been performed - not before. The system should then be allowed to cool, by driving the vehicle at the highest safe speed for the circumstances, without bringing it to a complete stop with the brakes still applied. After cooling the vehicle, a second set of ten partial braking events should be performed, followed by another cooling exercise. In some situations, a third set is beneficial, but two are normally sufficient.
for more details go to adam's rotors site. he has it all spelled out. he sells those same pads.
Old Jun 20, 2014 | 01:08 PM
  #14330
iSeeYouTwo's Avatar
Thanks for the info rob! I think I'm going to have a problem finding a place to do this though.
Old Jun 20, 2014 | 02:49 PM
  #14331
rawger's Avatar
I bet he has a blast driving at nighttime. Not like you need to see what's in front of you, right?
Old Jun 20, 2014 | 02:54 PM
  #14332
Harper's Avatar
Unregistered Member
Just do it on the highway.
Old Jun 20, 2014 | 03:41 PM
  #14333
robpp's Avatar
Graphite Ghost
yup highway at night.....
i found an industrial park right off the highway. between highway and airport.
Old Jun 20, 2014 | 05:32 PM
  #14334
Harper's Avatar
Unregistered Member
Bad picture of the LT Type S:
Old Jun 20, 2014 | 06:11 PM
  #14335
opboarding's Avatar
Hello World
Why are you not in your tsx harper? Blasphemy.
Old Jun 20, 2014 | 06:28 PM
  #14336
Harper's Avatar
Unregistered Member
Because of reasons.
Here's a TL with CU2 wheels. And a fail CLS 550.
Old Jun 20, 2014 | 07:36 PM
  #14337
xtcnrice's Avatar
Cls 550?
Old Jun 20, 2014 | 07:58 PM
  #14338
Harper's Avatar
Unregistered Member
Rebadged c300.
Oops, I meant to write CLS300
Old Jun 20, 2014 | 09:37 PM
  #14339
VR1's Avatar
VR1
Itz JDM y0!
CLS 300 lmfao. I saw a IS250 with a F sport badge on it.
Old Jun 20, 2014 | 10:00 PM
  #14340
rawger's Avatar
IS 250 F Sport is a real car though.
Old Jun 21, 2014 | 07:27 AM
  #14341
Vinny_P's Avatar
Love the CLS300.
You also see a lot of 3 series who add the M badge on...the quarter panels and the exhausts are always a dead give away...320 M for the win!!!!
Though when it's on a 335 you know they still have a serious car...but why ruin it by posing with a M badge.
Old Jun 21, 2014 | 11:55 AM
  #14342
Jaheri_cbp's Avatar
Yo! Idk about using this cheap orbital for polishing my car but when you spray lexol on the pad it makes one hell of a leather cleaner!! Holy shit this is awesome! Lol
Old Jun 21, 2014 | 07:42 PM
  #14343
MC MiYoung3269's Avatar
LOOOL
Old Jun 21, 2014 | 09:53 PM
  #14344
VR1's Avatar
VR1
Itz JDM y0!
Old Jun 21, 2014 | 11:01 PM
  #14345
Mercedes>BMW's Avatar
I Spit On You.
But who is William Lam? lol
Old Jun 22, 2014 | 03:14 AM
  #14346
rawger's Avatar
Good ol' Justin passing the solid white lines. So classless of him.
Old Jun 22, 2014 | 03:21 AM
  #14347
rawger's Avatar
Lol, never heard of buffing your seats, but good to know!
Old Jun 22, 2014 | 12:10 PM
  #14348
Harper's Avatar
Unregistered Member
So crabmans alive?
Old Jun 22, 2014 | 12:58 PM
  #14349
Jaheri_cbp's Avatar
Try it out I dare you!!
Old Jun 22, 2014 | 01:04 PM
  #14350
Jaheri_cbp's Avatar
http://youtu.be/NNDnjusKzhQ
Sorry that's William Hung
Old Jun 22, 2014 | 03:31 PM
  #14351
rawger's Avatar
She bang! She bang!
Old Jun 22, 2014 | 03:37 PM
  #14352
rawger's Avatar
Lol, I'm still looking to buy a polisher. I think I give up with eBay and will buy from a site. I was just wondering whether to get the 10-foot cord or 25-foot cord now. I found a pretty good deal with a coupon, though. It goes for 150 shipped on Amazon, but with a 16% off code + free shipping from AutoAnything, it can be had for 135. I just need to find out whether the 25 foot cord is worth it. I tried to see if they would price match Amazon and give the code, but they said no.
Edit: Looks like 135 for the 25ft is a good deal regardless since Amazon wants 140 for the 10ft.
Old Jun 22, 2014 | 09:53 PM
  #14353
VR1's Avatar
VR1
Itz JDM y0!
http://www.cars.com/go/search/detail...nal&listType=1
Old Jun 22, 2014 | 10:14 PM
  #14354
iCrap's Avatar
TSX AMG Type //M i-VVT
Drove up to Canada, the amount of nice cars here is crazy, while sitting in front of the hotel a SLS AMG, 760LI, m5, c63, f12, gt3 all passed me.
Also the number of riced civics is astounding.
Old Jun 22, 2014 | 11:54 PM
  #14355
xtcnrice's Avatar
Whereabouts in Canada? There are a lot of nice cars in downtown Toronto. But I like in the 'burbs... and the cars are like, 90% corollas/civics around here.
Old Jun 23, 2014 | 12:01 AM
  #14356
iCrap's Avatar
montreal yesterday and now quebec today.
Apparently when the f1 track is not in use you can drive your car on it, drove the odyssey on an f1 stage lol!
Old Jun 23, 2014 | 07:35 AM
  #14357
EhkoXC's Avatar
Wait, seriously? That sounds like a ton of fun.
I have a good friend who lives in Montreal. Time to take the TSX on a roadtrip!
Old Jun 23, 2014 | 07:53 AM
  #14358
iCrap's Avatar
Yea but i left out the part where you can only go regular road speeds
I dunno if they have days where you can actually race on it. that would be so much fun
Old Jun 23, 2014 | 07:54 AM
  #14359
EhkoXC's Avatar
Less fun in that case, but could still be worth it!
Old Jun 23, 2014 | 08:45 AM
  #14360
xtcnrice's Avatar
I love Montreal. Heading there next weekend
But yeah depending on where you are, there are alotta nice cars. Food is amazing as well
