09 TSX engine
Old Sep 26, 2008 | 03:27 PM
elezam's Avatar
Too much chrome
09 TSX engine
Does the new TSX share the same engine as the honda accord, or any other car?
Old Sep 26, 2008 | 06:04 PM
thunderbt3's Avatar
Pretty much same K24 engine thats in the CRV, Accord, and Element. The TSX engine gets a higher compression ratio tho so theres a boost of power but you must use premium fuel. VTEC switch point is also at 5K rpm instead of 6K rpm in the 1st gen TSX
Old Sep 26, 2008 | 06:09 PM
thunderbt3's Avatar
http://en.wikipedia.org/wiki/Honda_K_engine#K24
Old Sep 27, 2008 | 06:52 PM
elezam's Avatar
Too much chrome
So with regular fuel you would be fine?
Old Sep 27, 2008 | 07:16 PM
Colin's Avatar
The TSX uses 'true' VTEC on both intake and exhaust valves. This means you'll see three cam lobes over each cylinder on both sides. Accords and other K24s only have VTEC on the intake valves.
Old Sep 27, 2008 | 10:27 PM
dlee74's Avatar
So that holds true for the 1st generation too?
Old Sep 28, 2008 | 04:39 AM
Colin's Avatar
Yes
Old Oct 17, 2008 | 10:06 PM
evertp1's Avatar
Pushing 200
actually the 1st gen TSX's have 3 cam lobes on both the intake and exhaust camshafts! not just the intake... VTC is just on the intake cam gear as it is with every other K series i-Vtec motor out there
Old Oct 18, 2008 | 09:42 AM
soon4tsx's Avatar
The 2009 TSX, according to my Service Manual, has Variable Valve Lift and Timing only on the intake cam. The Exhaust cam is not used for VTC or VTEC.
jriv7
May 8, 2020 05:50 PM
cycdaniel
Dec 17, 2019 10:58 AM
Sep 14, 2015 10:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
