shocks
Originally Posted by 98tlracer
Or you can get the tokico illuminas and have it on the softest setting.
The illuminas allow for 5 damping settings. The HPs are about the middle setting (2-3) of the illuminas. Unless you track your car there's no need for adjustable damping IMO. Unless you get the Tein's with EDFC so you can adjust the damping on the fly.
I would say go with the Tokico HP's. Think about it, how often would you adjust the dampering on your struts? Not too often, so you save yourself some paper and go with the HP's. They are still good struts.
I lowered my car on EIBACH springs and love them but now need new struts...... My stock struts are slowly going out .. I have 19 inch rims Zennati's and would like suggestions on struts .... ANY IDEAS???????
so, can anyone give a straight answer??? to this question........
WHAT IS THE BEST STRUTS ANYONE WOULD SUGGEST FOR a 2003, TL-TYPE S, lowered on EIBACH SPRINGS , 19 inch RIMS??????? PLEASE just looking for a straight forward ANSWER..........
For starters how 'bout helping yourself and using the search feature cause this topic has been discussed more than a handful of times.
loaded question..
1st timer, you asked a loaded question when you ask the question on the sturts.. First of all what is your tast in cars (what are you use to driving in the past) and are you an aggressive driver? I personally think my 2002 tls stock suspension sucks for it is too soft and can not handle worth beans..
But since I added the CT springs, sway bar and koni yellows (current settings on the koni adjustable is soft at the fronts and 1/2 turn from soft in the rears) the car is an animal on the road.
BTW, I plan to go a littler firmer in te fronts (maybe 1/4 to 1/2 turn from soft).
The mods will defintally change your ride but again, I do not know your tast and if you like the stock struts, I will sell you my OEM parts
I figure you dislike the stock since you are planning to get replacments but its really your call.
But since I added the CT springs, sway bar and koni yellows (current settings on the koni adjustable is soft at the fronts and 1/2 turn from soft in the rears) the car is an animal on the road. BTW, I plan to go a littler firmer in te fronts (maybe 1/4 to 1/2 turn from soft).
trip to the bay area..
If you are in town, I will let you ride my car and you can see the difference.. My ride is the best of both worlds, tight on the hadling but smooth on surface roads.. I will not think you will be disappointed. The other day on the fwy i had to make a sudden manuveur (sp) for a car was coming into my lane when I was a high speed. I had to swerve (with out braking) to the emergency lane and snap back into the lane with NO issues. I did not even have time to horn or brake but the summary is that the new suspension can really get you out of some jams..
So for people still using OEM sway bars, they may want to set the rear shocks harder to make the car handling more neutrally. Later on if they replace the sway bars with aftermarket ones, they will want to soften the rear shocks because the stiffer sway bars will reduce the understeer or increase the oversteer of the car. Even different makes of aftermarket sway bars have vastly different stiffness. So with adjustable shocks, you can dial in different settings to maximize the handling performance of your car, and to suit your driving style (mild/heavy understeer/neutral/oversteer).
Originally Posted by 1st timer
i want firmer suspension but still want the comfort the TL has to offer.
For my car with stock suspension and CT sways, I always think its too soft on flat roads and too firm on rough roads. But it might mean different to you.
I figure you dislike the stock since you are planning to get replacments but its really your call.since I have eibach shocks do u suggest the same sway bars too??
Mr L..
I telling you that everyone with this car (2002 tls) should do thiese mods (sways, springs and struts) for you will see the difference int he 1st minute you drive the car. I can not tell you on any other products, for I have CT springs, CT sways and koni yellows. I would assume that the springs and the sways should be the same what even vendor you have and the difference will be in the struts. I had the yellows and CT's in my NSX and if they are good enough for that car, I would assume they are good enough for the TLS..
The hugh difference was in the sways and the struts for I had the springs with stock equip for 2 years and hated it for it was still soft. I telling you that you will not regret the mods if you enjoy to drive..
IIDXholic
3G RLX (2013+)
23
Oct 19, 2015 09:40 PM
4drviper
Sep 23, 2015 07:42 PM
