Need Help....
Old Aug 30, 2009 | 07:40 PM
Acura 02 TL-S's Avatar
Get Rich or Die Trying
Need Help....
I have a set of tein basic coilovers. When i twist all them up to about 10 coils and drop the car, the car is uneven.. is this because the shock are blows that why it not even out? i have to mix match the coilover like 5 coils on the left and 9 coils on the right for the car to be even in the front....
Old Aug 30, 2009 | 11:44 PM
hANDYcaptd's Avatar
It's the Halladay season!
I'd check if the coilovers are seated correctly first.
Coilover owners can chime in about the uneven stance...
Old Aug 31, 2009 | 08:51 AM
fsttyms1's Avatar
is this problem in the front or rear? Are the springs on the correct end of the car? (meaning front on rear rear on front?)
Old Aug 31, 2009 | 10:32 AM
SLaMMeD TL's Avatar
SOHC V-TEC
if its in the front. did you make sure that the Teins are all the way down in the front forks?? I would check that first and make sure that both the shocks are sitting correctly in the forks before doing anything. or make sure that the springs are both the correct one's meaning that they are not mixed up like fsttyms1 said?
Old Aug 31, 2009 | 02:48 PM
TheMegalodon's Avatar
I'm a thrill seeker in my
How uneven is it? My mechanic told me that about half an inch difference between the right and left side is normal (can't remember which side is lower than the other) to compensate for how our roads are sloped to one side (this may be an Albertan/Canadian thing).
I'm riding on Basics as well that I bought new and ride perfectly fine. They are all set exactly the same and there is a slight difference in finger gap from left to right. I asked my mechanic about the difference and that's what he told me, so that's what I'm going with (he worked for Honda for 10 years and runs the best shop in my smaller city).
Old Sep 1, 2009 | 10:16 PM
the 2 front and one rear. the one on the rear i have to twist the coils as far as i can to make it even on the other side. . I havnt checked if the springs are correct. How can u tell? they look the same to me.
Old Sep 1, 2009 | 10:17 PM
Yeah the tein are all the way down the folk.
Old Sep 1, 2009 | 10:20 PM
i dont get it, even if the shock might be blown shouldnt it still sits even because i have coilovers....
Old Sep 2, 2009 | 11:48 AM
Edward'TLS's Avatar
6G TLX-S
Depending on how much gas you have in your gas tank, the rear of a car with a full gas tank will sag much lower than one with a empty gas tank.
Old Sep 13, 2009 | 10:20 PM
the coilover are really for a accord does that affect the height? Any one know if it matter which size it has to go on either left or right side?
meowCat
Jul 2, 2014 04:04 AM
honda_motor_co_4life
14
Apr 4, 2007 03:17 PM
osyrhiz
1G CL Problems & Fixes
Mar 13, 2007 01:15 PM
