Lowering problem with wheel gap.
Old Jun 6, 2011 | 10:31 PM
808Dream's Avatar
7th Gear
Hey everyone I'm new to this forum, haven't done much to my TL. Just recently lowered my car with Eibach Pro kit. It's weird how the front has higher wheel gap then the rear . I don't like the look of it, I researched before purchase the kit. Thought it would be 1.7 for front and 1.5 for rear. I called Eibach tech and they said something bout cutting the bump stop, which I did not. But I don't think that would make the car sit high??
Old Jun 6, 2011 | 10:56 PM
jplasse's Avatar
2002 WDP 3.2
Possible that you accidentally put them on backwards? Did the springs not sit right in the tophats?
Old Jun 7, 2011 | 01:11 AM
TheMegalodon's Avatar
I'm a thrill seeker in my
This is a possibility. There have been rare occurrences where members have installed the springs on the wrong end or upside down. They then noticed a strange ride height similar to your situation.
Old Jun 7, 2011 | 08:30 AM
fsttyms1's Avatar
the front should have a slightly larger gap if you want the car to sit level. The front wheel arches are higher than the rear
Old Jun 7, 2011 | 10:15 AM
gold2003tl (90)'s Avatar
2003 TL-p
i agree, for a level drop the rear will have less fender gap than the front. That doesn't mean the rear is sitting lower than the front.
I am one of the few member to try the B&G kit and i love it, nice ride and excellent handling. It a pretty level drop, and does have a more fender gap in the front than rear. The front has slightly less than a 2 finger gap and the rear is about a 1/2 finger gap, still need to get a camber kit on the rear so that may change.
Old Jun 7, 2011 | 10:18 AM
808Dream's Avatar
7th Gear
no my buddy installed it right at the shop. I read instructions very well, but did not bother to trim the bump stop. I wonder if this gonna make the car sit higher.
Old Jun 7, 2011 | 10:30 AM
jplasse's Avatar
2002 WDP 3.2
could always get in there and cut out the bump stop (shouldnt require pulling the whole strut/spring out). and I dont recall what the shape is but if it is somewhat of an "accordian" shape, cut the first top section of the bump stop then split it in half to pull it off and see if it helps?
Old Jun 7, 2011 | 01:26 PM
Hmmm. I thought it maybe have been a significant difference. My Tein Basics are all set the same with a one finger gap in the rear and 2 finger up front. I guess you'd have to lower the front a little more than the rear with a very slight raked look to solve the uneven gap issue. You'd need coils, ground controls or koni sports with adjustable perches to do that.
Old Jun 7, 2011 | 01:56 PM
Rockstar21's Avatar
The Dumb One
which eibach springs did you get?
the pro-kit is 2.1 front and 1.7 rear.
Old Jun 7, 2011 | 10:26 PM
V_Langs_3.2TL's Avatar
Rice Patrol
my konis were always a little lower in the front (very last perch) than the rears (third to last perch)
my FF1s are the same way
rake and you'll crack an oil pan
Old Jun 9, 2011 | 01:54 PM
ddUMA's Avatar
i had a similar drop like yours and the bump stop were cut. im pretty even all around
Old Jun 9, 2011 | 01:58 PM
Rice Patrol
eibach says to cut the bump stop, but that doesn't mean you absolutely have to...
Old Jun 9, 2011 | 10:03 PM
Aznryda43's Avatar
2nd gens rock!
hey guy welcome to acurazine. they are right it might look like its weird but it sits level i cut my bump stops and my car is dumped..i think i have some pics in my gallery you can take a look at.
Old Jun 9, 2011 | 10:27 PM
proimport's Avatar
give it time to settle
Old Jun 10, 2011 | 09:00 AM
tc5280's Avatar
Flagship Aspec
Springs evenly drop "the body". you have to get coils to have an even gap, you would have to be raked because of the fenders being higher like fsttyms1
Old Jun 10, 2011 | 09:11 PM
Aznryda43's Avatar
2nd gens rock!
how long have you had the springs on your car?!
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
KillerG
Sep 4, 2015 02:02 PM
mtl_ilx
Sep 3, 2015 09:58 PM
