wtf is it??
Old Apr 17, 2007 | 10:00 AM
HockyStar89's Avatar
wtf is it??
im getting mixed answers on what this could be...my car is making almost like a grinding noise coming from the driverside wheel when i make turns...some say wheel berring ( which i thought was supposed 2 make a howling type noise) and some are saying its a warped rotor thats rubbing...these are all random service advisors giving me these answers..i trust this forum alot more
Old Apr 17, 2007 | 10:12 AM
pmptx's Avatar
Honda+Blue=My garage
Switch your rotors side to side and see if the noise moves to determine if it is the rotor (Or just get them turned)
As for wheel bearings, can't help much
Old Apr 17, 2007 | 10:30 AM
just bought new pads/rotors front and back...so maybe that will cure this annoying noise
Old Apr 22, 2007 | 01:00 AM
Colorado J's Avatar
wheel bearings or tie rod
Old Apr 22, 2007 | 05:19 AM
b1r469's Avatar
when was the last time you had your tires rotated? I had a similar 'grinding' noise from the car and it was nothing more than the tires wearing wierd and rotating the tires got rid of the noise. It's a cheap remedy to try.
Old Apr 22, 2007 | 07:17 AM
i still have my snows on...they come off on friday, itd be cool if that cured it
Old Apr 28, 2007 | 03:15 PM
Jayhawk_pat's Avatar
I had the same issue after have the front suspension serviced. My solution was to get a large screwdriver and pushing against the dust shield behind the rotor. No need to deform the shield, just push on it firmly in a few spots, you don't even need to take off the wheel. It solved my problem. The sound that I had was a faint grinding (metal on metal) when I turned left, from the right side.
Old Apr 28, 2007 | 05:54 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Had that going on with my fiance's Mitsubishi, got new tires, and the grinding noise when turning was gone.
Old Apr 29, 2007 | 05:22 PM
new tires, no sound
Old Apr 29, 2007 | 05:28 PM
01tl4tl's Avatar
How were the brakes when you changed them?
May be time to think about new snow tires for next year- those may have had it!
Old Apr 30, 2007 | 07:46 AM
brakes needed to be done before i put my snows on...snow tires were new this year and still in pretty good condition..so im kinda confused on what that noise was still
Rapture
Oct 4, 2015 12:05 AM
E92Vancouver
3G MDX (2014-2020)
Sep 21, 2015 02:32 PM
iCrap
Sep 11, 2015 06:21 PM
ahsm
Sep 9, 2015 08:35 AM
