Windows Issue
Old Mar 31, 2014 | 04:23 PM
tsaiduk's Avatar
Windows Issue
I have a problem with my windows in my 2nd gen.
3/4 Windows do not work.
-Driver Window (no click)
-Passenger Window (click)
-Rear Driver Window (click)
-Rear Passenger Window ( works)
I dunno how this works.
Old Mar 31, 2014 | 06:16 PM
3.2TLc's Avatar
Please attempt to better describe what is happening. "no click, click, works" doesn't help.
What all have ya checked so far. Maybe a bad switch, relay, motor or mutiplex unit ?
Old Mar 31, 2014 | 07:26 PM
Skirmich's Avatar
Yeah what the "clicks" means?? it makes a noise or something?
Old Mar 31, 2014 | 07:35 PM
tsaiduk's Avatar
when i press the button, it clicks/buzz where the window is. Like ill press the passenger window down and i hear a click click noise you know like when you light a stove or something.
Old Mar 31, 2014 | 10:43 PM
ErickUa5's Avatar
Mr.Helpful Diagram
I also hear the click on mines when you press up or down on any window.
tsaiduk is a good idea to let us know what year is your TL to better help.
My guess is a bad ground connection broken wire on the main widow switch(drivers Door) or burned fuse, check all fuses on the passenger side fuse panel.
Do the easy stuff first, check fuses.
Old Apr 1, 2014 | 11:03 AM
johnep's Avatar
Sounds like a motor or the regulator is stuck. If you can hear the click at the signaled window when powered up and down, the switch is good. If you only hear the click one way it would tend to be the switch.You may have to remove the door panels and inspect both. You could try to push a window down while soneoen hits the down buttom and free it up.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
mazen222
Oct 27, 2015 12:01 AM
govtcheez
Oct 1, 2015 12:21 AM
snorf
Sep 17, 2015 10:04 PM
ahsm
Sep 9, 2015 08:35 AM
