why my car shake
Old Jul 12, 2009 | 06:42 PM
viebotls's Avatar
why my car shake
I have a 02 tls every time I hit 40 mph my car vibrate its not my tire because i just got it rebalance with brand new tires also just got an alignment. This started happen ever since i lowered my car, can some tell me what the problem is?
Old Jul 12, 2009 | 10:28 PM
hANDYcaptd's Avatar
It's the Halladay season!
Check the axle. Common problem on lowered cars.
Old Jul 12, 2009 | 10:30 PM
viebotls's Avatar
so does that mean that i need new axle
Old Jul 12, 2009 | 11:37 PM
TLin401's Avatar
'13 Hyundai Sonata
Could also be your upper control arm and ball joints.
Old Jul 12, 2009 | 11:42 PM
desired_speeds's Avatar
id like to say axles or balljoints. Also check your tie rods.
VoLLy's Avatar
Meridian
I have the same problem. I am going to replace the wheel bearings first, if that doesnt fix it, im gonna replace the ball joints up front.
Old Jul 14, 2009 | 03:27 AM
viebotls's Avatar
i think im gonna check my ball joint first
Old Jul 14, 2009 | 08:20 AM
fsttyms1's Avatar
you should have some type of noise coming from the ball joint over bumps if it were bad enough to cause vibrations of some sort. My guess would still be rim/tire balance related even though its new tires or a axle.
Did the vibration happen right immediately after the drop?
Did you put new tires on because of the vibration or were they already on?
Have you tried rotating the rear tires to the front to see if it makes it go away?
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
