Weird start up, battery? starter? HELP!!!
Old Nov 18, 2009 | 03:55 PM
jgro650's Avatar
Hi guys, so today I went to start my car after it sat for the weekend and it wouldn't start. After a couple lengthy tries it started. Then about an hour later. I stopped at the bank and when I tried to start it there it just clicked when I turned the key. Then I tried again and it seemed like it was trying to start but only working half speed. Tried again it was at full starting speed but wouldnt start. Tried again and it started. I have no clue whats going on with it. Some people are saying battery? some starter? Ignition? Please help
Old Nov 18, 2009 | 06:29 PM
Rajca's Avatar
wham bam thank you ma'am
corrodes terminals? dieing battery? get ur system load tested at a auto shop. few bucks, but u will know whats up
Old Nov 19, 2009 | 07:34 AM
totaledTL's Avatar
While you chk. for corrosion see if any loose cables too. Don't wait until the middle of winter to address it-
Old Nov 25, 2009 | 01:58 PM
earthbound741's Avatar
Acura Newbe
i had similar problem. my fix was cleaning the positive terminal of the battery. i have no clue why i keep getting so much corrosion around it.
Old Nov 26, 2009 | 10:47 PM
totaledTL's Avatar
Apply some corrosion prevention grease, available at parts stores.
Old Nov 26, 2009 | 11:53 PM
juanclopez2786's Avatar
word ^ just get a wire brush to clean the terminals and then put grease on the battery terminals b4 u put the cables back on. it will definately prevent these problems from happening again. once its fully cleaned then have the charging system checked because if u dont the battery might fail due to the corroded terminals and you'll end up buyin a battery for no reason.
Old Dec 15, 2009 | 06:12 PM
Acura Newbe
well i dont have to worry about that for the next 2 years. just bought one recently and it came with 36 month warranty =D
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
jordanboi
Sep 5, 2015 01:33 AM
