Weird Knock Sound on startup
Old Jun 11, 2010 | 01:44 PM
dsm90awd's Avatar
8th Gear
2000 TL Auto
Just today I've noticed a peculiar knocking sound (like rapping your knuckles on a plastic storage bin) coming from under the p/s front dash immediately on engine startup that lasts ~30seconds and then goes silent.
If I turn the car off and back on, the sound re-appears.
The HVAC system was not on and I popped the hood and saw nothing rubbing/loose near the firewall. Is there some kind of servo under there (HVAC?) that does an "auto-check" on startup that may be sticking or something?
Old Sep 30, 2010 | 01:18 PM
dsm90awd's Avatar
8th Gear
Turned out to be the air circulator motor located in the P/S footwell. Seems the actuator arm was stuck and upon wiggling back/forth manually... no more noise .
Accordingto an Acura mechanic I spoke to afterwards.. a very common issue.
Old Sep 30, 2010 | 03:19 PM
acura1999tl's Avatar
I am getting the same noise for 30+ seconds. If temperature is at 90 (all the way in the right) its not heard. At other temps, it lasts for 30 seconds when you start the car.
I looked under the passenger glove box and notice the slippage, but manually pushing it does not seem to help.
Can you describe how you exactly fixed it?
SR
Old Sep 30, 2010 | 07:13 PM
dsm90awd's Avatar
8th Gear
I just unplugged it and worked the arm back/forth with my hand thinking it may have have gotten stuck. Yours may be fubared and in need of replacement if that does not work.
Old Oct 1, 2010 | 01:20 PM
twill220's Avatar
funny
i've just started having the same noises. this is a diy so i have to get on this immediately. thinking of sellin my 99tl because i want the 03tls. it has 191k and maintained very well...how much can i get 4 it?
Old Oct 3, 2010 | 03:28 PM
twill220's Avatar
r u talking about the wire plug that u unplugged. i see 2 of them but i think ur talking about something totally different that i dont see. can u describe what im lookin 4.thx
xsilverhawkx
Oct 5, 2015 11:00 AM
kb1rl
Sep 30, 2015 10:17 AM
merc009
Sep 29, 2015 03:06 PM
hashbrown
Sep 29, 2015 12:13 PM
STL TL-S
Sep 23, 2015 08:52 PM
