weird ac problem
Old Jun 9, 2011 | 12:09 AM
dc2kid's Avatar
weird ac problem
hey guys so my ac works fine but when its really hot oustide, the temperature goes up on the cluster then when i turn the ac off it falls quickly to the normal temp i had the coolant flushed last october does anyone know what it could be? sensor thermosat? i dont want to change everything fo no reason
Old Jun 9, 2011 | 10:45 AM
01tl4tl's Avatar
isnt this your 2nd thread on this subject??
Ck passenger side fan operates when ac comnpressor engaged
If not- thats your prob, ck fan for operation,,sensor, relay,,fozen fan??
Old Jul 9, 2011 | 06:25 PM
kak0019's Avatar
If you have a repair manual on the car, they should highlight testing procedures for the sensors in related to the compressor cooling fan. Check whichever sensor you think might be bad, 01tl4tl named pretty much all sensors that might be faulty. Testing them eliminates have to waste money on a sensor that isn't faulty.
Old Jul 10, 2011 | 10:01 AM
01tl4tl's Avatar
whats the results of the testing we sent you to do?
Old Jul 11, 2011 | 04:14 PM
dc2kid's Avatar
the ac fan works both fans work sometimes the driver side fan works after i turn the engine off for 5 to 10 mintues
Old Jul 12, 2011 | 04:37 PM
kak0019's Avatar
How far up does the temp gauge go? Almost overheating status? And I think 01tl4tl meant the repair manual procedures. I'm new to the site (I just got mine last weekend) but I've had a '91 Accord and did all the work on it myself since I was 16. Point being, even if you don't have a maintenance book, you should be able to find some test procedures on the site!
Old Jul 12, 2011 | 05:36 PM
my.daily'tl''s Avatar
Always Working In
the radiator(driver side) fan should remain on after engine shut off to help cool a hot engine. a hot engine will build up temperature once shut off and sitting still so the fan will run and try to cool the engine down.
according to your description, both fans seem to be operating normally. i think you need to check the sensors. something isnt kicking on when needed or... have you done a coolant flush recently? could be air trapped in your system.
Old Jul 12, 2011 | 06:26 PM
01tl4tl's Avatar
driver fan runs more than 1-2 minutes after shutdown means the fan temp sensor is failing
wont come on when needed during drive, then runs forever afterwards
replace that sensor and I bet the temp situation is resolved
look at passenger side bottem corner of rad- it screws in
see local parts store for new one
burp the system when done- make sure heater is on full hot so its contents are part of the flow during burping--it will hide air from you and cause probs!
Old Jul 12, 2011 | 09:16 PM
dc2kid's Avatar
i got a used sensor of my friend and still heated up ill try it with a new sensor this week and could it be my rad i dont think it was changed for a while.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Skirmich
Oct 1, 2015 12:59 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
