Way to turn A/C off permanently using Auto Climate
Whenever I turn on the climate control it usually kicks in with the A/C for which I have to manually turn off the A/C using the A/C button.
Is there are way to run the climate control similar to other cars where you turn on the fan and if its too hot you just turn on the A/C?
Thanks for all the great info on this board.
Yeah but I'm trying to find a way not have to turn off the A/C each time I turn on the climate control. I want to turn it off and make it stay off until I tell it otherwise.
just dont use full auto. If its not on full auto the AC is on only when you turn it on. and you have full control of the fan speed.
so the compressor remains all all the time if u have the climate control on FULL AUTO??
or it goes on/off.....i doubt that cuz the temp remains constant in the cabin! so its gotta be on the whole time!! man..a lotta gas i say?
A/C compressors aren't using more than 5-7 HP anyway, so I wouldn't lose any sleep over whether you have it on or not. The benefit of a comfortable cockpit far outweighs the miniscule amount of power to be gained from having the compressor off.
If you were talking about a 125 HP 4-banger, it would be a different story...
Hey Maestro,
Then maybe you can you can answer this for me...the reason I want to turn it off is because I feel that I lose some power in my 02 TL (100k) when I have the A/C running. When it's off it just seems to me that my car accelerates smoother and shifts more consistenly. This is really only noticable in stop and go city driving.
Does that sound normal for a 3.2 V6?
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
Originally Posted by rezn8
Hey Maestro,
You might want to take it in and see if the A/C clutch is still working correctly and have them check all of your belts too.
My TL-P 02 with 75k miles do the same thing . Compressor of the A/C turn on/off too frequently and this will affect my acceleration .
Originally Posted by TL Maestro
No, that doesn't sound normal at all. I have an '02 as well, 120,000k and it still pulls like it did the first year I had it, and I'm running the A/C non-stop out here in sunny So Cal.
Hey Maestro,
If you dont need the AC on simply push the button to turn it off. there is no need to run the ac on all the time.
You answered my question in your first post. By not using full auto, the AC wont doesn't come on unless I turn it on. Appreciate that...thanks.
Originally Posted by acurabum
Hey REZN , try to put your climate control in AUTO ... the compressor of my car will cycle and engage less and the car picks up better . Try it ....and keep me posted
Rezn8 : no .. no ..no ...A/C will engage the compressor in AUTO if the temp that you set is lower then the outside temp.
Update : I recenly wash/clean my engine and feel my car lost a bit more of it pick up
when the A/C is on .........So I did put a few drop of engine oil at the
A/C compresor pulley to try to lubricate it and amazingly the car pick up smoothly
and drive a lot better when A/C is on .
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
