wants to stall when coming to a stop
Old Nov 27, 2008 | 04:14 PM
TOTAL~LUSH's Avatar
2003 acura TL type S 130,000 km's
sometimes when i pull up to a stop light the engine wants to stall out. the rpm's will drop close to 500 or so and it's starting to chug and then picks back up again. might do it a few times at the next few lights and it might only do it once. seems to be intermittent. everything else is fine for driveability and no check engine light.
i was thinking egr or maybe fuel pump. would a tps do this?
any ideas?
Old Nov 27, 2008 | 04:27 PM
01tl4tl's Avatar
I would get the codes checked- see if any EGR related ones come up
Could just be dirty EGR ports, those get plugged bad by your km's
Check the diy for thermoblock spacer install and egr cleaning, you remove the intake manifold to get to the ports.
Other probs would be dirty IAC idle control or dirty injectors-dirty TB throttle plate
You can DIY an intake cleaning for those with seafoam or bg or wynns products
Hows the spark plugs? have you changed them?
Old Nov 27, 2008 | 09:23 PM
phipark's Avatar
Not Asian
I would definitely start with the IACV.
Old Nov 28, 2008 | 02:08 PM
twistedwedge's Avatar
6MT Someday..
wouldnt a faulty IAC and or EGR cause the CEL to come on?
Old Dec 1, 2008 | 01:02 PM
chewi's Avatar
it could also be a weak battery
Old Dec 2, 2008 | 05:39 AM
TOTAL~LUSH's Avatar
nope I have an optima red top thats about 6 months old. I am going to keep an eye on it cause it hasn't done it since i posted this thread. it is supposed to get colder in the next week or so and i will watch for it then.
Old Dec 2, 2008 | 06:41 AM
newperson's Avatar
There's no Acura in
You never know. I once bought a new battery and had issues with it within months (e.g., needing to get jumped a lot). The true culprit was my alternator.
Old Dec 3, 2008 | 05:31 AM
TOTAL~LUSH's Avatar
yes you are correct you never know. but with your car the problem was the alternator so your new battery was infact good. and i have a good size stereo and have no problems starting or anything like that. this problem happens when the car is already running. and from my previous experiences with alternators they usually just die. never had an intermittent problem with an alternator.
i wonder if it is maybe the throttle cable sticking.
Old Dec 3, 2008 | 10:12 AM
fsttyms1's Avatar
There have been many cases of intermittent alternator issues on this forum. Especially in the early stages. I would still clean the TB and the IACV.
Old Dec 4, 2008 | 06:05 AM
TOTAL~LUSH's Avatar
yeah i am going to get it cleaned this weekend.
For future reference what are the symptoms of the bad alternator?
01CLOwner
Oct 9, 2015 01:07 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
PortlandRL
Sep 14, 2015 12:01 PM
theinsvnity
Sep 10, 2015 10:22 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
