UR Crank Pulley Installed Now check engine Light is on
Old Apr 12, 2007 | 11:53 AM
EL19's Avatar
I had my UR Pulley set installed not too long ago (its the underdrive set) and wen i gun it and almost redline the check engine light flashes sometimes. anyone ever had this problem or know if it was installed incorrectly? thnx
Old Apr 12, 2007 | 01:09 PM
fsttyms1's Avatar
It just flashes then goes away?
Old Apr 12, 2007 | 02:54 PM
Souped's Avatar
yea its weird
Old Apr 12, 2007 | 02:55 PM
EL19's Avatar
yea so i can never pull the code
Old Apr 12, 2007 | 03:19 PM
fsttyms1's Avatar
then its just a random misfire code. There wont be any code stored. Its not from the pully or a botched install. How many miles on the car. If the plugs are original you may want to look into replacing them. Give it a while and see if it continues as well.
Old Apr 12, 2007 | 07:13 PM
EL19's Avatar
ok yea i have 71K on the car.. but i changed the plugs to the denso iridums at 60k...ill giv a a while and see if it stops..i appreciate the help
Old Apr 12, 2007 | 07:16 PM
01tl4tl's Avatar
Theres your problem
Those densos are good for maybe 30k for normal driving and you want max power from them= good luck
I suggest a Seafoam treatment to make sure all the inner parts are clean and then install NGK Iridium plugs- or Platinums but use NGK they outlast outwit and outperform the denso
Old Apr 13, 2007 | 08:40 AM
EL19's Avatar
wow ok yea thats a blower i planned on seafoaming asap but good to know now i need new plugs...those are goin in tomorrow morn thnx fellas
Old Apr 13, 2007 | 10:02 AM
fsttyms1's Avatar
just give it some time before you go and replace them. Let the ecu change (learn) any parameters it might and see if it continues
Old Apr 13, 2007 | 10:13 AM
EL19's Avatar
aight cool thnx again...ill probably still seafoam tho
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
iCrap
Sep 11, 2015 06:21 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
NSolace
Sep 3, 2015 08:14 PM
