UR Crank Pulley Installed Now check engine Light is on
I had my UR Pulley set installed not too long ago (its the underdrive set) and wen i gun it and almost redline the check engine light flashes sometimes. anyone ever had this problem or know if it was installed incorrectly? thnx
then its just a random misfire code. There wont be any code stored. Its not from the pully or a botched install. How many miles on the car. If the plugs are original you may want to look into replacing them. Give it a while and see if it continues as well.
Theres your problem
Those densos are good for maybe 30k for normal driving and you want max power from them= good luck
I suggest a Seafoam treatment to make sure all the inner parts are clean and then install NGK Iridium plugs- or Platinums but use NGK they outlast outwit and outperform the denso
2005, acura, cel, changed, check, crank, crankshaft, engine, incorrectly, installed, installing, light, pulley, pully, tl, underdrive, ur
