turning the alarm off without the remote
Old Nov 8, 2010 | 06:27 PM
kingstonn's Avatar
I tried turning off the alarm without the remote by putting the key in the driver door and unlocking and locking it but it doesnt seem to work. Is there a way to turn the alarm off without completely disarming it or using a remote.
Old Nov 8, 2010 | 09:34 PM
01tl4tl's Avatar
why do you say it didnt work? the key will disarm it
did you open the driver door and the alarm triggered?
If the red light on the door is not flashing- the alarm is off
Old Nov 8, 2010 | 10:01 PM
kingstonn's Avatar
do i have to put it in the ignition, because just turning it on the driver side door does not disarm it, alarm kept going off until i used the remote.
Old Nov 9, 2010 | 01:49 AM
01tl4tl's Avatar
dont have the owner book in front of me--have you registered with acura.com as owner? you can get free owner book online there
Old Nov 9, 2010 | 12:47 PM
The 03 CLS Owners Manual states:
The horn sounds and a combination of headlights, parking lights, side marker lights and taillights flashes if someone attempts to break into your car or remove the radio. This alarm continues for two minutes, then the system resets. To reset an alarming system before the two minutes have elapsed, unlock either door with the key or the remote transmitter.
It sounds like you may have a fault at the door lock.
Old Nov 9, 2010 | 02:22 PM
totaledTL's Avatar
Are you using the valet key? Not sure, maybe that key won't disarm it @ the door-?
Old Nov 9, 2010 | 04:41 PM
01tl4tl's Avatar
the valet key wont let them into the glovebox or thru the rear seat pass thru assuming you locked both of them with the real key
you need to engage the trunk lockout inside glovebox for full protection in valet parking
Old Oct 5, 2015 | 07:34 PM
David Thompson's Avatar
having same issue.
Did you ever figure out how to turn it off? I am having same problem.
Old Oct 6, 2015 | 12:11 AM
Chojun's Avatar
I'm pretty sure you can't without the remote. But you could try putting the key in the door and holding it in the unlock position - ordinarily that will unlock all 4 doors after 1-2 seconds - maybe it will turn off the alarm?
Old Oct 6, 2015 | 12:43 PM
Curious3GTL's Avatar
Put the key in the ignition and turn it to the "On" position. It worked on my 2000.
Old Oct 6, 2015 | 12:52 PM
i pop the hood and undo the battery.
Old Dec 29, 2018 | 01:14 PM
BG58's Avatar
I had the door handle replaced on my 2002 Acura RL. Now or can't turn the security system on or off with the key. Before I had the door handle, I could turn the key to the left to turn the alarm on and turn the key to the right to turn the alarm off.
Old Jan 3, 2019 | 10:56 AM
03TLSinCO's Avatar
I have an issue with some sort of parasitic drain on my battery, causing it to run down if I don't use the car for a couple days. When I connect jumper cables to the car, the alarm goes off. Putting the key in the door and locking/unlocking it stops the alarm (my remote doesn't work). If the OP's car doesn't work that way, there's likely another issue, either with the key or the lock.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Azonics
Sep 22, 2015 05:28 PM
GraveDigger
Sep 18, 2015 07:46 AM
Sep 17, 2015 09:01 PM
