transmission leaking
I suggest you clean it and see where the oil is coming from
Ericua5 (10-06-2017)
just so we understand correctly, you changed out the engine for a newer one and kept the old transmission? Did you take the torque converter out of the transmission at any time? If so, when you reinstalled the TC you could have ripped one of the seals.
like Thoi said. you will have to completely clean the area to see where the leak is coming from. If it's coming from the very bottom where the torque converter is then you will likely have to pull the transmission to investigate further.
well guys i dropped the trans and i finally found out the problem. seems like the ody block i had on the car pushed the torque converter back and was rubbing against the trans. it had a hairline crack on it but i know the casing is done. on the search for a transmission right now thanks for eveything
micro23
11-22-2016 04:19 PM
boorah623
10-10-2016 06:30 PM
rets
09-09-2013 02:43 PM
