Transmission Advice
Old Mar 15, 2012 | 12:57 PM
bytwnracer's Avatar
5th Gear
Transmission Advice
I have a 2002 Acura TL Type S with 77,000. The original transmission is now failing (I did have the oil jet recall done). I have a buddy who works at a transmission shop who can rebuild my transmission with the updates according to his books for $1000. I have read about people swapping the transmission for 3rd gen tl, 06-07 accord, or 03-07 oddessy transmission. I found a used transmission with 55,000 miles (no way to verify, transmission is out of car) that I can buy and put in for about $1000. So either way is going to cost me about the same.
Now I am stuck at a cross road and do not know what to do. Should I rebuild my transmission, and if so how much can I expect to get out of the rebuilt transmission? Or am I better off doing the swap?
Any input would be great!!! Thanks
Old Mar 15, 2012 | 01:39 PM
666wokker's Avatar
Do the swap, get a 06-07 Accord trans, has the updated castings.
If you rebuild your current one, you will be in for the same repairs.... at least with the AV6 swap, there's a much less chance of it failing the same way (clutch packs starving for fluid)
Old Mar 15, 2012 | 01:51 PM
bytwnracer's Avatar
5th Gear
The transmission I found was for a 06 TL. Does this one have the updated castings? Or should I just keep looking for 06-07 Accord transmission?
Old Mar 15, 2012 | 09:09 PM
666wokker's Avatar
*Supposedly* all casting after 05 have the internal updates, but I have seen some ramblings on the net about the TL and Oddy trannies having the same issues....
Personally, I would go for the Accord trans, better bet there
Old Mar 16, 2012 | 08:17 PM
totaledTL's Avatar
https://acurazine.com/forums/2g-tl-problems-fixes-117/transmission-solved-2006-2007-accord-tranny-works-great-841309/
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
