Ticking Noise
Old Feb 12, 2006 | 07:22 PM
fodzy147's Avatar
Ticking Noise
I have 2 wierd noises coming from my car that are not normal. the 1st is a loud errrrrrrrrrrnt(I know bad interpretation but best i could describe it) about 20 sec or so after starting car and does it 2 times then goes away. Next is a high pitch ticking/ whining noise that only happens when car is moving sounds like possibly from right side. Any ideas wut theses are?
Old Feb 14, 2006 | 09:33 PM
deniro7862001's Avatar
5th Gear
I think mine has the same issue.....sounds like its coming from underneath the car right underneath the rear door somewhere. i cant figure out or pinpoint where its coming from..but it sounds like a bomb or something...its not a sharp ticking sound...its more of a "dull" sound...if that makes sense..any help would be great.thanks... 99 TL
Old Feb 15, 2006 | 01:47 PM
MikeekiM's Avatar
The two "errrrrrnt" noises (I've always heard them described as buzzing noises) are normal and are caused by the ABS system initializing...
You should get one of them at about 5mph, and another about 15mph I recall... It used to bother me, but after discovering that it was normal, I don't pay too much mind to it anymore...
As far as the whining noises, I cannot help you there... Good luck!
Old Feb 15, 2006 | 06:48 PM
fodzy147's Avatar
Ya i did some reading and the whining is possibly 1 of the wheel bearings is in need of replace. Im glad to know the other 2 sounds are normal. Im taking my car to the dealer on monday to get the whining checked out ill let u guys know what happens.
Old Feb 15, 2006 | 08:39 PM
fsttyms1's Avatar
Thats the evap canister. Its normal.
Old Feb 16, 2006 | 01:15 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
First we need to know if the two whirring, buzzing sounds occur when you are moving, or when the car is sitting still. ABS and VSA do not self test unless you are rolling, so if you are still sitting still, have it checked.
If you ARE rolling, this is normal since you have VSA. On VSA cars both systems test, meaning you'll experience two of the whirring sounds. On ABS/TCS TL-Ps it only happens one time.
If the noise happens from a wheel.. is it a whine, or is it a screech? If it's a screech it's probably just a brake pad wear indicator - you need new pads. If it's a whine, you might want to look into wheel bearings as mentioned.
Old Feb 20, 2006 | 07:59 PM
fodzy147's Avatar
Turns out that the owner before me had put in the wrong air filter in so the car wasnt getting the air right. The noise was caused by that.
Old Feb 20, 2006 | 08:00 PM
fodzy147's Avatar
turns out the owner before me put the wrong air filter in so the car wasnt getting the air right that was causing the noise.
Old Feb 21, 2006 | 12:28 AM
5th Gear
Hey thanks for the help...is there any way to get rid of that noise..can i replace it? It is really annoying...when its sitting still....
Old Feb 21, 2006 | 10:08 AM
fsttyms1's Avatar
Yes it can be gotten rid of. You will need to replace the part. Its the big black box located on the drivers side near the rear tire. (#5)
If you hear the sound from under the hood area its the purge control selonoid
Old Feb 22, 2006 | 12:26 AM
5th Gear
Hey thanks for your help. It doesnt seem like its coming from under the hood of the car, sounds like its coming from underneath the rear door somewhere...but i cant pinpoint where its coming from. i guess ill take it to the dealership and hopefully they can figure it out!Thanks again
Old Feb 22, 2006 | 07:52 PM
fodzy147's Avatar
the purge control selonoid can echo underneath the car and can be heard inderneath the rear doors on occasion. open your hood with the engine started and listen up towards the top right u will hear some ticking, then go by the rear door ur hearing it from and if it is the same sound then it is just the purge control selonoid echoing. mine does it and dealer said its normal.
Old Feb 22, 2006 | 08:50 PM
fsttyms1's Avatar
the first pic i posted its coming from #5. many have that issue (the EVAP Canister)
Old Feb 3, 2007 | 01:21 PM
Raf06TL's Avatar
I called the dealer on this noise, they did say it was the evap; now, if the noise is normal, Why have it replaced??
Old Feb 3, 2007 | 02:12 PM
fsttyms1's Avatar
Because some dont like the noise. Not all do it, but its a common issue.
Old Feb 4, 2007 | 07:39 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
i always wondered what that noise was. mine makes that same errrr noise especially if im making a suddent stop
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
