throttle body issue !!!!! need help !
Old Mar 15, 2008 | 08:03 PM
jimmiexiong's Avatar
i have a humming noise from my engine, come to find out that the outter throttle that connects to the air intake stays open! is this normal or is something wrong, plz help! i do notice my gas mileage is very bad! any help would be great!
thnkz
jimmmie xiong
Old Mar 15, 2008 | 10:30 PM
NSXNEXT's Avatar
Totally normal. That's the VSA unit and it's normally open.
Old Mar 16, 2008 | 07:22 PM
thnkz for the reply! but is it suppose to stay open even when the engine is off?
Old Mar 16, 2008 | 08:37 PM
01tl4tl's Avatar
Do you mean that 2 inch diameter plate inside the Throttle Body? That controls air inlet
and should be sprayed with carb cleaner or TB cleaner
What was the car doing before the noise- did you/anyone do any work on it?
what year and miles?
What kind of fuel economy. less than 20mpg in town?
Have you changed the spark plugs, air filter recently?
Old Mar 16, 2008 | 08:53 PM
Rajca's Avatar
wham bam thank you ma'am
it stays open when the cars on or off and i think it closes when it feels that your front tires are spinning. check if u have your intake resonator in (the part that is in the bumper, under the filter, that will cause a hmmmm.
Old Mar 17, 2008 | 12:13 PM
Montaigne's Avatar
2000 TL
What tells it to open or close?
Old Mar 17, 2008 | 12:20 PM
01tl4tl's Avatar
the computer tells everything what to do
Old Mar 17, 2008 | 12:33 PM
Montaigne's Avatar
2000 TL
Right. I understand that, but what sensors is the computer relying on? Just wheel speed or also the power steering sensor in the tranny? Just trying to run down the possibilities for my idle problem.
Old Mar 17, 2008 | 08:21 PM
yes the plate that opens & closes! the car was fine nothing/ no mechanical ( no tranny issues either, still on original tranny)issues, its a 2003 tl type s with 93000 miles i use premium only, yes my gas milelage is kinda bad, i changed the plugs & filter after i first noticed it when the check engine light came on, but it still does the humming, & it stays open! my question is does it stay open like that?
Old Mar 17, 2008 | 08:26 PM
Rajca's Avatar
YES stays open all the time unless u spin your tires and then it closes. my gas mileage sucks too. really badly, around 210-230 to a tank. (but i have a heavy foot)
NSXNEXT's Avatar
Yes, it only closes when the ECU indicates it needs to reduce power to the wheels.
Go back and check the filter. Stick your head under the hood and listen for where the humming is coming from.
Old Mar 17, 2008 | 08:27 PM
idle problem? i would check & replace plugs, make sure you are using same grade fuel( if you use premium stay with it ect !) and check ur coils, most of the time itz misfiring in ur engine! in one of the valves!
Old Mar 17, 2008 | 08:30 PM
okay, i got that out of the way now! you learn something new everyday ! lol
it does seem to come around the air intake area! the acura technicans say its my headers! i was like huh?
thnkz for all the help! it does make more sence now!
Old Mar 17, 2008 | 08:33 PM
Rajca's Avatar
might have a leak in the headers. (cracked, loose)?
Old Mar 17, 2008 | 08:40 PM
dont really know, but if it is , is it a problem that is detrimental? i was planning on replacing the headers anyway with the comptech! not anytime soon though!
but headers seem to be fine to my mechincal standards, maybe bad gaskets?
Old Mar 18, 2008 | 08:43 AM
NSXNEXT's Avatar
Header bolts might just need to be retightened. Or you have a bad weld that is causing air leakage.
Old Mar 18, 2008 | 08:44 PM
Rajca's Avatar
i have a leak somewhere in the gasket and it hisses not hummmmms happens around (1200-2500rpm)
cycdaniel
Dec 17, 2019 10:58 AM
ryanfett
Oct 29, 2015 06:01 AM
BigJilm
Sep 21, 2015 08:32 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
