throttle body issue !!!!! need help !
i have a humming noise from my engine, come to find out that the outter throttle that connects to the air intake stays open! is this normal or is something wrong, plz help! i do notice my gas mileage is very bad! any help would be great!
thnkz
jimmmie xiong
thnkz
jimmmie xiong
Do you mean that 2 inch diameter plate inside the Throttle Body? That controls air inlet
and should be sprayed with carb cleaner or TB cleaner
What was the car doing before the noise- did you/anyone do any work on it?
what year and miles?
What kind of fuel economy. less than 20mpg in town?
Have you changed the spark plugs, air filter recently?
it stays open when the cars on or off and i think it closes when it feels that your front tires are spinning. check if u have your intake resonator in (the part that is in the bumper, under the filter, that will cause a hmmmm.
Originally Posted by jimmiexiong
my question is does it stay open like that?
Go back and check the filter. Stick your head under the hood and listen for where the humming is coming from.
Originally Posted by Montaigne
Right. I understand that, but what sensors is the computer relying on? Just wheel speed or also the power steering sensor in the tranny? Just trying to run down the possibilities for my idle problem.
Originally Posted by NSXNEXT
Yes, it only closes when the ECU indicates it needs to reduce power to the wheels.
it does seem to come around the air intake area! the acura technicans say its my headers! i was like huh?
thnkz for all the help! it does make more sence now!
Originally Posted by Rajca
might have a leak in the headers. (cracked, loose)?
but headers seem to be fine to my mechincal standards, maybe bad gaskets?
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
