thermospacer kit engine problems; CAN'T DRIVE!!!
Old Mar 8, 2009 | 09:35 PM
DaveS221's Avatar
finished installing kit and when I start the engine, a loud hissing noise comes from the engine (can't pinpoint where because the noise is so loud) and the engine revs up and down. Iv disassembled and reassembled everything three times now, checking all the hoses, gaskets, proper torquing of the bolts, and cleaned the IACV. what am i missing or what is going wrong?? my car has been undriveable for 2 weeks now and i'm getting frantic
Old Mar 8, 2009 | 10:07 PM
SLushhYYY's Avatar
Keep It Simple in
If this happens at idle it is most likely a leak in the throttle body spacer. You can either tighten the bolts or spray some throttle body cleaner around the spacer to close the leak. Did you completely remove the old gasket?
If it happens while driving, its normal.
And the engine revs should go away after a quick drive. You tampered with the throttle cables, so the computer needs to readjust I guess. Or you didnt reattach throttle cables. Your getting more air in through the throttle body so uhh yaahhh.
WHY IS IT UNDRIVEABLE???????!!!!!!!!
Old Mar 8, 2009 | 10:22 PM
DaveS221's Avatar
trust me when you turn the engine on, the sound is loud as hell. i reattached the cables and revved it a few times trying to make the revving stop. ill take it for a drive but im very concerned that by doing so i could be messing sumthing up... with the car started, i can hear the noise its making from inside my house... ill tighten the TB bolts a little more (already have them at 18lbs) and try the TB cleaner..
Old Mar 8, 2009 | 10:27 PM
SLushhYYY's Avatar
Keep It Simple in
Yah, mine leaked and made a really loud hissing noise which got louder as the engine got hotter. Do what I said, tighten bolts and spray WD-40 or Carb Cleaner around the Spacer. Its not the cables...
You cant really mess anything up.
DaveS221's Avatar
^ its driveable, but not the kinda driveable where i would want to be driving this kinda car around like that. if i was in the middle of the desert with a POS old pontiac or sumthin that would b a different story..
Old Mar 8, 2009 | 10:28 PM
DaveS221's Avatar
Ok, ill do that and get back to you
Old Mar 9, 2009 | 01:45 PM
acutee's Avatar
Double check to make sure you didn't crosslink the vac lines.
Old Mar 9, 2009 | 01:52 PM
fsttyms1's Avatar
Sounds like a vacuum leak. DONT drive the car. Find whats wrong. Also like above, make sure you dont have a coolant line going into a vac line.
Old Mar 9, 2009 | 02:39 PM
NSXNEXT's Avatar
Do not spray anything the spacer. You have a textbook vacuum leak. Recheck all the hoses, retorque all the bolts.
Old Mar 9, 2009 | 04:36 PM
DaveS221's Avatar
didn't spray anything. took it apart, checked the hoses and reassembled again today. all the hoses are in the right spots and are intact. torqued all the bolts to specifications and thoroughly cleaned all the parts. still there is a leak. im at a loss... any ideas?
Old Mar 9, 2009 | 04:54 PM
SLushhYYY's Avatar
Keep It Simple in
Did you completely remove the old gasket??
Old Mar 9, 2009 | 06:58 PM
Edward'TLS's Avatar
6G TLX-S
Remove the kit and restore back to OEM configuration. Now you know if the kit is causing the problem or if the hoses are assembled wrong.
Old Mar 9, 2009 | 08:20 PM
fsttyms1's Avatar
Agree.
Old Mar 11, 2009 | 09:13 AM
DaveS221's Avatar
did so. car works fine now without it. I'm going to contact them and see wuts wut.
Old Mar 11, 2009 | 11:31 AM
fsttyms1's Avatar
one of the gaskets was causing a vacuum leak. Are you sure they were put on properly?
Old Mar 11, 2009 | 11:36 AM
jjashaa's Avatar
Avant Garde Wheels
you install the spacers right with the gaskets???
there's a certain way you have to install them...
i can't find the instructions i had on this computer but recheck all the stuff
even the gaskets...
if its bad.. lay the spacers flat on a flat table to see if you can see any gaps and stuff...
Old Mar 11, 2009 | 04:40 PM
SLushhYYY's Avatar
Keep It Simple in
Thats excatly what was wrong with mine. Nothing a little bolt tightening, and WD-40 couldnt fix..........
Old Mar 11, 2009 | 09:15 PM
totaledTL's Avatar
How is WD40 going to cure a vacuum leak?
Old Mar 11, 2009 | 10:38 PM
SLushhYYY's Avatar
Keep It Simple in
IDK , but it fixed my air leak.....maybe clogged up the leak?
Old Mar 12, 2009 | 01:47 AM
Gfaze's Avatar
S E L L
even the gaskets...
I remember reading that these spacers have to be installed in a certain position. Re-read the instructions, it should mention it in there.
Old Mar 12, 2009 | 01:48 AM
Gfaze's Avatar
S E L L
WD40 didn't fix your leak, tightening the bolts did.
Old Mar 12, 2009 | 12:08 PM
slavver01's Avatar
03 ABP tls
you sure you have the right spacer kit too right? when i ordered mine for the tlp, they by accident sent me a kit for a type s, so some of the holes didnt line up. they obviously sent me a new one with no problems, awesome customer service but yea make sure you have the right one
Old Mar 12, 2009 | 12:12 PM
jjashaa's Avatar
Avant Garde Wheels
and certain order if i remember correctly... gasket spacer and manifold.. or something... i dunno...
SLushhYYY got mindfu*ked...
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Desert Ridge
Sep 5, 2015 09:47 AM
