stuck in manual mode
IN MY TL
i have a 99 tl with 01 swap in it and it is stuck in manual mode i can reverse it and go into all the gears just wont go into automatic mode HELP
Do you have the 5 speed ECU?
It has to be a connection. If you swapped the wiring, ECU/trans/motor etc that's really all it can be. I dont think the engine compartment to cabin harness are different or would cause that, nor should the under hood relay center. Either that or the trans is bad?
then i would unplug and look at all trans connections and make sure all pins are straight. make sure every thing is plugged in fully to the trans.
IN MY TL
okay i have been too busy to take my car to acura so maybe saturday i'll let you guys know. i did however finally get a chance to pull the eclipse out so thats cool
Can you get the codes read?
IN MY TL
finally back at acura lea mechanic working on my car every single light was on tcs abs srs cel but thankfully the tranny is good just an electrical connection should be done monday
IN MY TL
so i picked up the car today and it runs great now i have one more problem the only lights that work on my car brake lights work and head lights but parking lights dash lights and taillights are out fuses are all good that i found
Biggie_B
02-26-2017 11:14 AM
MetalGearTypeS
08-29-2016 08:28 PM
