Strange Audio Issue....Steering Wheel Controls
Old Nov 20, 2009 | 11:58 PM
LAMike240's Avatar
In the last couple of days, I am getting the following behavior from the volume controls on the steering wheel of my 03 TL-S:
When I hit the down button, the volume will actually go up. If I keep hitting the down button, eventually the volume will start to go down.
In addition, the radio station may change.
This behavior is intermittent. Any ideas?
Thanks,
Mike
Old Nov 23, 2009 | 09:15 PM
acurabum's Avatar
I got the same problem with my TL-P 02 and the Acura service Bulletin said is a bad ground of the volume/control unit inside the steering wheel.
I did not want to remove the Air Bag so try to live with the problem .
Old Nov 24, 2009 | 07:08 AM
fsttyms1's Avatar
Dont look at it as having to remove the airbag. Look at it as having to remove the steering wheel. The airbag is one solid unit and you wont have to repack it or install it wrong. Its a easy thing to do and many have done it.
Old Nov 24, 2009 | 07:40 AM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
I had the bad clockspring ground problem and fixed it, but this sounds like it may be a different problem-mine didn't behave as Mike described.
Mike-quick test-with engine running of course, turn the steering wheel 90 degrees in either direction and see how the radio controls work in that position. If they work right doing this, it probably is the ground problem. Cruise control buttons and horn can also be affected.
Removing the air bag is Soo easy a cave man could do it...no problem for an Acurazine member
Old Nov 24, 2009 | 09:50 AM
bigeshorte45's Avatar
i had same problem, then horn stopped working as well as cruise control, turned out to be bad "clockspring reel", ordered the part off of acuraoemparts and had a shop fix it, everything works fine as of now...
Old Nov 24, 2009 | 12:38 PM
AlanW's Avatar
Hate to hear that, you can fix it with a little screwdriver, about an hour of labor, and $0.00 There is an Acura service bulletin that walks you through it step by step.
Old Nov 25, 2009 | 01:32 AM
LAMike240's Avatar
Thanks for the info guys. I'll try the 90 degree test.
Alan is that the TSB that requires putting dimples in the copper ring?
Thanks,
Mike
Old Nov 25, 2009 | 07:49 AM
AlanW's Avatar
Re: TSB
Thanks,
Mike
Yes-that is the one. light hand pressure with a small, pocket-sized flathead screwdriver is all that is needed to make the dimples. The copper ring is really thin.
Old Nov 25, 2009 | 08:20 AM
fsttyms1's Avatar
Thanks,
Mike
I would try the TSB with the dimples before buying any thing. It may be your issue.
Old Nov 25, 2009 | 10:03 AM
juanclopez2786's Avatar
if u need the bulletin let me kno i have it and can email it to u
Old Dec 1, 2009 | 09:42 PM
acurabum's Avatar
Juan : could you confirm on what model year/month the service bulletin is ?Thanks
Old Dec 1, 2009 | 09:51 PM
Applies To:
1999–03 3.2TL – ALL
2001–03 3.2CL – ALL
2001–02 MDX – ALL
January 20, 2006
Old Dec 2, 2009 | 09:36 PM
acurabum's Avatar
I check the Service Bulletin for Acura on the Jan/2006 and it's not there ??/
Old Dec 2, 2009 | 10:19 PM
i copy and pasted it from the actual bulletin
Old Dec 3, 2009 | 09:48 AM
99AcuraTL03's Avatar
is too sexy for his shirt
we had the same problem on our old honda odyssey and found out it wasn't the ground just the connection kept getting loose from the turning
Old Dec 12, 2009 | 11:33 AM
jhal's Avatar
Hello, I just bought my wife a used 2003 TL-S and it is having the same issue with the audio buttons. I'm usually pretty handy at fixing these little quirks, but can't find the service bulletin that describes how to fix it. Do you have a link to this bulletin? Thanks in advance!
Old Dec 12, 2009 | 01:08 PM
jhal's Avatar
I actually found the link. In case anyone else needs it, it is
http://www.in.honda.com/rjanisis/pubs/SB/B03-015.pdf
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
