stero
Old Oct 13, 2010 | 10:56 AM
iiNFAM0uS RAJA G's Avatar
stero
i lost my code for my car and i was wondering how can get it because i changed my cd player the old one was bad and i got a new one
Old Oct 13, 2010 | 11:21 AM
01tl4tl's Avatar
was it a warranty swap? or you bought a radio and lost the code,,or this is a new set to you,,not running yet
ck diy and net search--there is a way for certain years to be forced to give up RADIO code by pushing the 1 and 6 buttons (iirc) and something with the key
otherwise you have to remove the radio to get the secret serial number off it
take that to the acura parts dept or service manager and they can look it up
Proof of purchase on the unit and your id can help if they dont know you
I got a warranty nav dvd some years ago and acura forgot to write the new code down!
wasnt that fun removing dvd unit several times. calls to corp,,many different code attempts,,sure glad the SM had been treated to ice cream and donuts--no charge for all the hassle to get me a nav code
and it was their responsibilty to have written it on the warranty invoice and noted in customer file
NOTE on acura.com owner account you can safely store the radio nav codes!!
such is life
tip: many years find the code wont take until you go to a covered parking structure--under a building,, and/or disconnect radio antenna,, from driver side panel for acces
then it goes in fine
Old Oct 15, 2010 | 01:50 PM
the old was wasnt working when i bought the car a year ago so i decided to buy one of from ebay and i got the code with it but now i dont remember where i put the code and yeah my friend also gave me that tip to go under a parking lot or building.
Old Oct 15, 2010 | 05:40 PM
dudeinaTL's Avatar
The radio will never give you the radio code. The 1 & 6 method only gets you the serial number. And not that it really matters, but there's two possible radio codes for each serial number.
Old Oct 17, 2010 | 04:44 PM
no i mean i bought a new radio from ebay and took out the old one and put in the new one, i know there arent 2 codes for any radio and i wanted to know the 1 and 6 trick you know how to do it?
Old Oct 18, 2010 | 12:25 AM
dudeinaTL's Avatar
Just hit 1 & 6 and then turn on the radio. It'll give you two 4-digit numbers; the upper & lower portion which make up the serial number. If you call ACS, they'll instruct you on what you should do.
Old Oct 18, 2010 | 06:51 AM
01tl4tl's Avatar
each year varies on its abilty to give up the code
often acs/800 will tell you take it to the dealer so they can remove the radio at a charge of 1.5 hours~ and get the serial num off it
did you look in the diy section yet?
contact seller and ask for code!
get their cars vin too- to show legal chain of ownership
Old Oct 18, 2010 | 10:29 AM
i might call the try the 1and 6 buttons or ill probably change the stero and get an aftermarket one so lets see what happens
clrider665
Nov 1, 2007 08:31 AM
free2befast
May 31, 2007 06:52 AM
pyromasta
Jul 13, 2006 11:36 PM
Andynolife
1G TSX Problems & Fixes
Nov 1, 2004 07:53 PM
KUMO
Jan 7, 2001 11:26 PM
