Steering rack replace
Old Dec 16, 2010 | 04:19 PM
Iggy's Avatar
Can I get away with not having to remove the steering wheel if I'm careful to have everything all centered when installing the new rack? Any tips from the experts out there.
Thanks,
Iggy
Old Dec 16, 2010 | 04:59 PM
01tl4tl's Avatar
do a search for steering rack and post by fsttyms1 in the last 3 months
He put written instructions up for another ziner,,no diy but at least some help
Old Dec 17, 2010 | 08:46 AM
rcb2000's Avatar
you don't need to remove the steering wheel or anything to do with the steering column. the coupling should be keyed so it only goes on one way. Now you'll want to get the toe checked and steering wheel centered after you install the new rack, odds of getting the tie rods adjusted so the toe is right and the wheel is center is almost impossible since there are slight variations in the rack your removing and the one your installing.
Old Dec 17, 2010 | 08:49 AM
Iggy's Avatar
Thanks guys. It seems the Type S racks are hard to find in my neck of the woods so it'll be a few days before I tackle this .
Iggy
Old Dec 17, 2010 | 09:03 AM
tc5280's Avatar
Flagship Aspec
Mine just started leaking too, f@#&! good luck
Old Dec 17, 2010 | 10:35 AM
01tl4tl's Avatar
if rack is bad from fluid crud destroying seals- use seafoam and flush system a few times to prepare for new parts
www.seafoamsales.com tech section will have the procedure
Old Dec 23, 2010 | 09:57 PM
Iggy's Avatar
What a PIA. Took me 7hrs including upper control arms and new end links. Tighter than my high school GF. LOL
Old Sep 20, 2011 | 12:50 AM
Jose Amarillas's Avatar
Did you have to drop the subframe in order to get enough clearance to get the steering column off the pinion?
TL-Rocket
Apr 29, 2023 02:33 AM
spidermankb
Mar 5, 2019 11:34 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
Snafunk
1/2G MDX (2001-2013)
Sep 3, 2015 08:01 PM
