SRS 3 trouble Codes
Old Dec 18, 2010 | 12:53 PM
M T L T L's Avatar
Red face SRS 3 trouble Codes
the 9-04 and 15-02 can be cleared but the other comes back on as soon as I turn off and on ignition.
The 1-01 looks pretty serious to me. Would this prevent my airbag from deploying in case of an impact ?
Old Dec 18, 2010 | 01:12 PM
01tl4tl's Avatar
call the dealer with your VIN
there is a recall out for airbag inflator, something about deployment speed
they replace a sensor, not the airbag
and its free!!
everyone needs to be registered with acura care- they send the recall notes
1 800 382 2238 x5 gets a human
Old Dec 18, 2010 | 01:14 PM
01tl4tl's Avatar
there is also a special 10year/150kmiles SRS and seatbelt warranty
If your belt retracts slowly or sticks or has a buckle prob as code indicates-= another freebie!!
Old Dec 18, 2010 | 01:15 PM
01tl4tl's Avatar
Note If you have done ANY electrical work on the car and then got a SRS light- follow the reset procedure in the DIY section
If it comes back on see dealer
if it comes on and no work was done, call dealer asap
Old Dec 18, 2010 | 01:29 PM
M T L T L's Avatar
I've done the fog light mod. SRS light came on after that, idk how long after but I was able to clear it with the MES connectors. And after some months it came back on and this time it wouldn't go off with the MES connectors trick. Would you suggest I undo my fog light mod before showing this to the dealer ?
Old Dec 18, 2010 | 07:07 PM
01tl4tl's Avatar
I dont know what the fog light mod uses for power
the normal issue must be a power spike splicing wires etc (my guess) with battery connected causes false codes
If its been months since reset, thats a different story= time for dealer
Old Dec 18, 2010 | 07:10 PM
01tl4tl's Avatar
hope for it being part of the recall (its a usa recall- may cross over)
you can also ck your acura.com account recall section--I dont have the Canada website but its been posted here before
or call 1 888- 9 acura 9 in canada for help
Old Dec 18, 2010 | 09:04 PM
M T L T L's Avatar
The fog light mod draws power from instrument panel fuse to the fog light toggle switch through a diode. My only concern is if the dealer sees this, could they hold this against me and not honor the extended warrant or recall?
Old Dec 19, 2010 | 04:33 AM
01tl4tl's Avatar
they would have to - by law- prove the mod caused the problem!
thats why no hassles on lowered cars and trans failure
but wont cover cv bearing on lowered cars, as thats a direct provable relationship to wear
take it in and tell them the SRS light came on,
the service writers rarely convey your actual words to paper for the tech- all they get is: Customer states SRS light on
Leave a note in car for the tech explaining you tried reset etc,etc
give whatever details you have to help, include codes you pulled
Dont clear the codes!!!
Old Dec 19, 2010 | 04:35 AM
01tl4tl's Avatar
did you call or ck your myacura account to see if recall covered on the inflator part?
internet probably has the vin list too
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
brboy
Oct 5, 2015 11:34 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
