Speed Cluster
Old May 15, 2013 | 04:12 PM
I03's Avatar
I03
3rd Gear
Speed Cluster
my speedometer stopped working, got it checked out and they told me its the whole cluster thats not working. The speed sensor is fine. my questions is if i buy a new cluster online and install it will the mileage stay the same , would it update itself? or will it have the mileage that's on the used cluster.
Old May 15, 2013 | 04:48 PM
3.2TLc's Avatar
Has anything else stopped working ?
If the entire cluster was bad, then one could assume that a fuse or connector is causing the problem.....have them checked before replacing the cluster.
Old May 15, 2013 | 09:45 PM
I03's Avatar
I03
3rd Gear
Just the speedometer is not working, the odometer and all gas and other things are working fine.
Old May 16, 2013 | 06:48 AM
3.2TLc's Avatar
Hey I03, Ya said that the VSS speed sensor was ok......unsure, but I think there's actually two of them.....an input and also an output speed sensor ?
Old May 16, 2013 | 07:33 AM
fsttyms1's Avatar
You can buy just the speedometer and install that for 30 bucks new. If you replace the whole cluster you will loose your mileage and get the mileage from that cluster. Mileage is kept on the cluster.
Under Meter Components
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old May 16, 2013 | 07:35 AM
MilwaukeeDave's Avatar
You can get the speedometer cluster only and simply replace that. It's fairly easy to remove the whole cluster, then take it apart and swap just the speedometer section. It pulls right off the board as an assembly.
CL-S progression 01
Jan 26, 2016 04:15 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
Houston
Oct 8, 2015 01:27 AM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
hashbrown
Sep 29, 2015 12:13 PM
