Shifter won't shift into gear
Old Aug 16, 2005 | 05:05 PM
adominguez7's Avatar
4th Gear
The shifter won't shift into gear until I pump the brakes several times. Has anyone had this issue. I called the dealer and the guy said it could be the brake lights switch that sits on the break pedal... Any ideas?
Thanks!
Old Aug 17, 2005 | 08:55 AM
bkzjimmy's Avatar
NiGhT rIdEr
Thanks!
happened to me a while back, couldnt get it outta park at all and the brake lights didnt even come on. but those were the good ol days when i was still under waranty. so i dont know how much its gunna run ya if ur not covered.
Old Aug 17, 2005 | 10:09 AM
cljw's Avatar
Happen to me once about a year ago, It has never happened again. I Mentioned it to the dealer as I was taking it in for something else a few days later, and they could not find anything wrong. I has not happened since.
Old Aug 17, 2005 | 10:22 AM
fsttyms1's Avatar
most likely its the brakelight switch
Old Aug 17, 2005 | 11:29 PM
Speed42005's Avatar
Break light switch.. check ur break lights too... ask any person to look at break light if it's working..
Old Aug 18, 2005 | 10:12 AM
4th Gear
Thank you guys...
I changed the brake Light switch by the Brake pedal and sure enough the problem went away.
Thanks for your suggestions!
Old Aug 18, 2005 | 11:23 AM
fsttyms1's Avatar
Old Aug 25, 2005 | 10:54 AM
bkzjimmy's Avatar
NiGhT rIdEr
YOU CHANGED IT????? HOW????????????
cause lastnight i couldnt get outta park again (for the second time)
so i put it in N by sticking a key in the shift release and shut the car off, then when i turned the car on everything worked again.
im still gunna have to bring it to acura cause the SAY the fixed it the last time!
Old Aug 25, 2005 | 11:07 AM
fsttyms1's Avatar
im going to step out on a ledge here and say he did it by taking out the old (bad one) and installed a new (good one)
Old Aug 25, 2005 | 12:42 PM
bkzjimmy's Avatar
NiGhT rIdEr
i meant did he do it or dealer? cause i think mine is going and i wanted to know how to and how much is the part. if my stealership says its not the part they fixed like they said about the SRS problem i had!
Old Aug 26, 2005 | 03:21 PM
4th Gear
The part # is 36750-S84003 and it runs around $35. I changed it myself it is really easy 5-10 mins.
By the way, I had this happen to me once about 2 months ago and then it ran fine until it finally started to happen every single time I would start my car... so if it's happened to you once go ahead and replace it before it goes out on you for good.
Old Aug 27, 2005 | 12:13 PM
bkzjimmy's Avatar
NiGhT rIdEr
thanx alot
Old Feb 28, 2007 | 12:49 PM
Type34's Avatar
Follow-up to this problem's solution ...
This is an old thread, but I found it in the archive when looking for the solution of why my car's shifter wouldn't come out of park.
As a follow-up for those having the same problem, I installed a new brake light switch and the problem didn't go away.
I then saw a thread in the Acura Legend forums that said the horn + brake lights + shifter are on the same fuse. I figured that my '03 TL-S may be the same. Well, the fuse layout in the owner's manual is subpar, but after looking around, I found the fuse. It's the STOP 20A fuse under the hood (next to the Horn relay). I replaced this fuse and it fixed the problem.
If anyone is interested, I now have a new Brake Light Switch for sale
Also, the guy at the dealership said sometimes the plastic pad that the brake light switch contacts can crack and fall off (so the switch is "on" constantly). So if your problem is reverse (your brake lights are always on), replacing the $1.95 plastic pad may just be the answer.
Hope this helps!
Old Aug 10, 2007 | 08:33 PM
Michaels144's Avatar
Hi, I just found this old thread. I know this is a TL site, but my Integra won't shift out of gear (and I didn't find anyone who's done this elsewhere). If the problem is the brake pedal switch, then I need this part: 36750-sr3-003 apparently. However its difficulte to loosen the lock nut on the switch because there isn't much swing room for a wrench. If someone has done this here, and they were able to remove their switch easily, I'd really like to hear how they did it.
Old Aug 22, 2007 | 06:08 PM
1enoch's Avatar
This forum saved me some $$$, my 02 TL wouldn't shift so I used the manual shift lock release today to get around town. I called the dealership and they said check the brake lights, which didn't work! So they said to bring it in so they could put on a new switch. They were going to charge me $120 so i was about to just order the part myself for $35 when I read this forum about the fuse problem. Sure enough, I checked my horn and it didn't work either! Replaced the STOP 20A fuse and it fixed the problem instantly!!
Old Sep 8, 2007 | 01:15 PM
srees01's Avatar
I have a 2000 TL with 95000 (second tranny in case your wondering)
I had this problem about 3 months ago and the dealership replaced the brake switch part. But yesterday it started up again. Now I have no brake lights when I put pressure on the peddle but they do work when I "unlock" from the key pad??? I just checked the horn it works fine. Do you think the switch could have gone bad already? I might have to bring it back to them. Also, my SRS has been on for about month - is there a recall for that?
Thanks in advance.
Old Sep 8, 2007 | 03:06 PM
fsttyms1's Avatar
sounds like the switch went bad again. As for the SRS light, it could be a few things (of which should be covered) but we cant say for sure till you get it diagnosed
Old Sep 8, 2007 | 03:12 PM
srees01's Avatar
I'll let you all know... I have a good relationship with the service manager at the dealership and I'll see if they can check it out on monday.
Old Sep 8, 2007 | 08:22 PM
dpham's Avatar
Heys, any DIY on doing this? would help lots thanks!!
Old Sep 8, 2007 | 10:16 PM
01tl4tl's Avatar
crawl under dash, look at brake pedal- remove wire connector at switch- remove nut holding switch in place
Install new switch and nut-replace wire
check adjustment for when the brake lights come on- so if you tap the pedal you get brake lights
Old Sep 11, 2007 | 02:15 PM
srees01's Avatar
Update: I didn't have a lot of time to install last night (my wife took me out for my brithday - great steaks). Anyway, I did quickly plug in the new brake light switch and the lights instantly worked again. However, I did have the hardest time getting the old brake light switch out ... that damn thing is on really tight! Which nut should i be trying to loosen? The one closest to the firewall looks like it is part of the bracket... am i right on this. Any help is appreciated..
PS: I am stopping by the dealer on Friday to get the SRS looked at... i'll let you all know what that was when i find out. Service manager thinks it might be a seat belt sensor. Guess we'll see.
Old Sep 11, 2007 | 06:04 PM
srees01's Avatar
Figured it out... just had to stop being afraid of breaking something... everything works fine now... except the SRS light (save that for friday).
Old Sep 12, 2007 | 12:17 AM
1enoch's Avatar
My SRS light has also been on a couple months now. I haven't gotten around to getting it checked out yet. I'm interested in what it might be. I figured it was most likely some kind of sensor problem.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
agupta3224
Sep 22, 2015 08:08 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
JetLife2324
Sep 17, 2015 05:59 PM
