!!! Seafoam in oil !!!
~~~ SKY'S THE LIMIT ~~~
so ive read about puttin SEAFOAM in the oil to clean all the bullshit thats in there
i know yer suppose to put a CHEAP oil filter on b4 ya put the seafoam in the oil to catch all the crude
QUESTION-----what about puttin more oil to make up for what was in the filter ??---should i put more oil in and if so how much oil ???
ALSO-----how much SEAFOAM should i put in the crankcase ????
THANKS GUYS !!!
THANKS GUYS !!!
you only need a new filter before IF the oil looks like total crud AND you plan to do the extended miles method of cleaning--then its possible to overload the filter if it was already near full--not likely on normal engine~
the filter holds less than 1/2 qt,,with the seafoam added you will still be in the range for correct oil level--ck dipstick if concerned and and a few ounces of oil _ I never have
use 1.5 oz per qt oil- basically 1/2 can seafoam into oil
either drive 30 minutes and change oil, or drive over the course of a week with some 30 minute runs if possible
its heat and time that make seafoam work best
Important to change warm!!-15 minute freeway cruise, so all the sludge is liquid, or it stays on the bottem of the oil pan instead of draining out
ok cool---THANKS MAN---APPRECIATE IT ALOT
another question too---i have been using castol gtx high milage oil
10w 30----WHAT ARE YOU USING IN YER CAR ????
what is the best oil to be running in my 99 TL with 175K miles on it
i also use a K & N oil filter since the day i got the car from alabama and it came off the trailer ---whats yer opinion on that ??
2003 TL-p
any full synthetic will outperform gtx high milage. and using 10w-30 is unnecessary. i am using castrol edge 5w-30, very good oil. as well as mobil1 ep, vavoline syn power and pennzoil ultra. redline and amsoil are the best oils though.
ok cool---thanks for the help guys
i was actually at wallmart and they didnt have any castrol 5w 30 high milage---and i was gonna get that castrol edge 5w 30 but i didnt know it if was good---but now i do---so much appreciated man
THANKS FOR THE HELP AND ADVICE
2003 TL-p
the new edge is suppose to be reformulated with titanium and be better than the old edge, believe its available in 5 quart jugs at walmart now. I dont buy into castrols marketing junk and crazy tv ads. But edge is an excellent oil, runs smooth and powerful, also provides extended drain intervals. Im pretty impressed with my current fill and might stick with edge, engine runs great with edge probably run it out to 10k miles interval. Also mobil 1 extended performance is excellent for the money, iv used that with confidence in many applications. if you shell out a little more cash you can go amsoil or redline for ultimate oil performance.
also dont forget to get a good oil filter, especially if you plan on running extended drain intervals.
B A N N E D
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
![Whistle](https://acurazine.com/forums/images/smilies/whistle.gif)
and btw a good oil filter is recommended every time (and maybe even change it half way through, if you must do really extended oil changes)
B A N N E D
personally i use carquest's 85334 BLUE line filter (not the red line one, which is their cheaper one)
and i think i pay like $10 or something for it (
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
and as far as the synthetic oil, i use schaffer's oil (can be kinda hard to find at times though) http://www.schaefferoil.com/
and here is a kinda funny story about using it too, last December i did a baseline dyno run on my car, after having swapped to a 6-speed, and i noticed the shop was also using schaffer's oil too, cause one of the boxes was on the ground to help pick up any oil drips on on the dyno; and they like the oil also
IBankMouse
06-13-2020 12:53 PM
acuratl26
04-23-2020 07:30 PM
