Replacement clock light bulb dim
Old Dec 6, 2011 | 09:54 PM
nishant11's Avatar
I had a blown light in clock in my 2003 TL S last week. My mechanic brought replacement from local Acura dealer but replaced light appears dim compared to A/C display even at full brightness of dimmer switch.
The labor cost to replace the bulb which requires instrument panel is much higher than the bulb itself hence I am reluctant to spend money again.
Has anybody faced such issue?
Old Dec 7, 2011 | 11:47 AM
totaledTL's Avatar
Look up the bulb part # online & verify that it matches the bulb that was installed. There can be different wattage bulbs of the same base type, size, etc. Higher wattage = more light output. Maybe a substitution was made.
Old Dec 9, 2011 | 08:25 PM
Luke7's Avatar
WNC Real Estate Sales99TL
I need to replace mine also Can't wait to tear the dash pieces off to get to it!
Old Dec 9, 2011 | 11:30 PM
soria's Avatar
I replaced mine with LEDs and its the same issue. The AC is much brighter than the clock. I think the climate unit has multiple bulbs whereas the clock only has one. Plus the clock has a plastic diffuser that further diminishes the output. It just seems to be designed that way.
IMO, Acura should have made the clock at least as bright if not brighter than the AC display.
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
wusty23jd
Sep 24, 2015 11:41 AM
theinsvnity
Sep 10, 2015 10:22 PM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
