Remember that thread...
Old Jan 8, 2012 | 09:16 PM
deepconcentratn's Avatar
There was a thread that someone post about a transmission filter on 2nd Gen trannys. I tried searching but can't find it to save my life. It was a filter that no one new existed until he found it. It had pictures and everything. Can someone help.
Old Jan 8, 2012 | 09:48 PM
Skirmich's Avatar
That may be the OEM Tranny Filter? What do you Need?
Old Jan 8, 2012 | 10:00 PM
Skirmich's Avatar
If you Follow the ATF Cooler DIY you can Find the "ATF Filter Line"
I think all 4 Bolts are 10mm but I can be Wrong dont remember.
Just un-screw those 2 bolts Holding the Filter Line then the other 2 Bolts Holding the Filter Bracket, Unscrew the Filter like the Engine Oil but with less force please, Drop In the new Seal and Filter, reverse procedure and DONE.
Part NO: 25450-P7W-003 (ATF FILTER) - 25 to 45 Bucks.
Old Jan 9, 2012 | 06:58 AM
totaledTL's Avatar
This one is pretty useful:
https://acurazine.com/forums/showthr...+filter&page=3
Source:
https://acurazine.com/forums/showthr...mission+filter
Old Jan 9, 2012 | 10:54 AM
Thats it! I am starting to have some transmission issues and I am hoping a drain and refill will do that trick.
I am going to try changing the filter. Lord knows I don't have 2K to spend on a tranny.
Old Jan 9, 2012 | 12:06 PM
totaledTL's Avatar
Recently did it myself as a preventative measure- not having transm. issues. Wasn't too bad.
Old Jan 9, 2012 | 12:21 PM
01tl4tl's Avatar
deep- try a selenoid/pressure switch cleaning and a new filter
along with the 3.4 qt change to new honda dw1 atf
are you getting slipping in gear or reluctant to grab the next gear?
give us a hint and more suggestions may appear
a filter isnt going to cure any INTERNAL trans prob- it just filters !!
BUT
it its clogged that would create an issue
This is something we should all do,,just like flushing brake fluid and ps fluid.
good preventative at the least,, and could solve some probs at best!!
Old Jan 9, 2012 | 03:42 PM
soria's Avatar
For the '99 TL folks; we don't have that transmission filter.
knight rider
Mar 4, 2016 08:59 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
stogie1020
Cameras & Photography
17
Sep 30, 2015 01:34 AM
4drviper
Sep 23, 2015 07:42 PM
