rear lights not working
Old Mar 15, 2010 | 01:29 PM
edouglas1's Avatar
Angry rear lights not working
1999 acura tl:For some reason all of my rear lights stopped working. I went through inspection this morning and noticed this. Prior to today they were fine. The only thing I can think of different is I used my emergency brake during inspection. Can this cause brake light failure and how do I fix?
Old Mar 15, 2010 | 03:54 PM
fsttyms1's Avatar
All the lights or just the brake lights? Did you check the fuses?
Old Mar 15, 2010 | 04:41 PM
edouglas1's Avatar
Just the rear brake lights, all lights are out except for the two clear lights near the top of the housing. these only come on when gear is in reverse. not sure why they failed all of a sudden. fuses appear to be fine not sure which ones control the rear break lights? any help is appreciated.
Old Mar 15, 2010 | 07:49 PM
fsttyms1's Avatar
When you turn the lights on the tail lights dont light up? Or only when the brake is applied? Do the blinker lights work?
If you arent sure which ones work the brake lights then how are you sure they appear fine? There are 3 fuse panels on the car. hHich ones control the tail lights are in the manual (i dont remember off the top of my head)
Old Mar 16, 2010 | 09:43 AM
edouglas1's Avatar
I'm sorry for the confusion, when I turn on my headlights, all of the rear lights come on. My signal lights (right and left) work also. Do you think it has anything to do with the switch located behind the brake pedal. I had time to run a few more diagnostics yesterday and the fuses are fine. Your input is valued, thanks
Old Mar 16, 2010 | 10:16 AM
fsttyms1's Avatar
So the only lights that dont come on are your brake lights. If that is the case first check the brake light fuse. If that is ok then i would look at the brake switch. Do you have any problem getting the shifter out of park and into drive
Old Mar 16, 2010 | 10:30 AM
edouglas1's Avatar
Emphatically yes! I have been using a small allen wrench to shift from park to other gears. Once out of park, just fine. What is the meaning there?
Old Mar 16, 2010 | 12:12 PM
edouglas1's Avatar
I have been using a small allen wrench to shift from park to other gears. Once out of park, just fine. What is the meaning there? Also which fuses are hHich or are these relays?
Old Mar 16, 2010 | 01:09 PM
rcb2000's Avatar
adjust the brake switch
Old Mar 16, 2010 | 01:24 PM
ANC297's Avatar
Bonki' Ehrite!
You need a new Brake Switch....Its about 30 bucks from Advanced auto and takes only a few minutes to change out.
Check the DIY section for instructions....
Basically, when you press the brakes, this solenoid tells the brake lights to go on, it also lets the system know that you are pressing the brake pedal. The system does not allow you to shift out of park if you are not on the brakes... since the switch is fried, when you press the brakes the computer does not know, so it does not allow the car to shift out of park. Also, be careful when driving, until you replace this you will not have brake lights.
Old Mar 16, 2010 | 02:00 PM
fsttyms1's Avatar
Your brake switch is the problem. Replace it and your problems will be fixed.
Old Mar 16, 2010 | 02:06 PM
edouglas1's Avatar
Superb, I really appreciate you guys input and I will follow up by replacing the brake switch. Thank you much!!!
Old Apr 3, 2010 | 05:10 PM
dnel99tl's Avatar
99 tl brake lights not working
can anyone solve this problem? my brake lights are not working, i replaced the bulbs the fusses are good and the brake stop switch is okay.all the other lights are working.what am i missing.
Old Dec 29, 2016 | 01:20 PM
Jag Preet Singh's Avatar
Tail light not working
hi there
my tail lights are not working when i turn on the lights
but when i press brakes all lights works properly.
all the signals are also working properly. and also my odometer lights has stopped working.
any help will be appreciated
thanks
Old Dec 28, 2017 | 11:35 AM
Vanessa Gonell's Avatar
Help!!
Originally Posted by Jag Preet Singh
hi there
thanks
Did you ever find any solution?! I am having the same exact problem.
Old Dec 28, 2017 | 11:37 AM
check your fuses
Old Dec 28, 2017 | 06:13 PM
check your fuses
the fuses and bulbs are good.
Old Dec 28, 2017 | 07:53 PM
Chojun's Avatar
The odometer lights is a different problem than the brake lights. That's a problem with a small circuit board in the gauge cluster. You can fairly easily pull the cluster out and replace the board for around $50 if you do it yourself.
Also keep in mind that the brake light bulbs have 2 filaments in them. A dim and a bright one.
There is a fuse in the engine bay fuse box labeled "small lights" (from what I remember) - check that.
Old Dec 29, 2017 | 04:32 AM
Iggy's Avatar
Are the front side marker lights and license plate light working with the headlight switch to on? If not then it could be the tail light relay which is in a box just above the brake fluid reservoir. Black rear relay on drivers side
Old Aug 13, 2021 | 07:36 PM
Dex 7's Avatar
my rear lights don’t work
my turn signals work and while pressing the brakes the lights light up as well but the parking ones?don’t light up could it be the brake switch ??? (acura tl05)
Old Aug 13, 2021 | 10:56 PM
brake light switch is only for the brake lights
which lights are the parking lights????
jhoop2
Nov 9, 2019 12:52 AM
acvega
Aug 1, 2015 01:30 AM
sara
Mar 27, 2015 09:40 PM
gibbyisgibby
Aug 13, 2014 07:50 AM
thumperc25
1G CL Problems & Fixes
Mar 29, 2008 09:22 AM
